Washing Machines Logo
Posted on Aug 26, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 6kg Fisher Paykel Front Loader washing machine AWF 60 MD!! I currently use daily load option and when it gets to rinsing it stops !! I have drained the water out of the bottom of the machine and nothing seems to be blocking it either but it still stops on the rinse and then i can only go around to the spin option to finish of the load !! Can you help me at all please !!!
keith jones
Level 3:
Master:
  • Fisher and P... Master 747 Answers
  • Posted on Oct 29, 2017
keith jones
Level 3:
Master:
Answers
747
Questions
Helped
314816
Points
1478
I think you may have something stuck in the pump or its faulty
5 Related Answers
Anonymous
  • 1294 Answers
  • Posted on Mar 13, 2008
SOURCE: fisher & Paykel Smart Drive 9 Pride
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it (4 to 6 inches maximum). Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Mar 29, 2008
SOURCE: Fisher and Paykel Smart Dribe 608
not familliar with that exact model number ( we dont have that over here in the US) we have simalair f&p gwl10- gwl11) that problem sounds as if either the pump is bad and overheating before pumping all the water or a diverter valve is not fully closing allowing water to remain in tub.
Anonymous
  • Posted on Nov 16, 2008
SOURCE: Fisher & Paykel GWL11 Top-Load Washer troubleshooting
I've had my washer for about 8 years. I experienced the same problem - pump stopped draining the machine. I called F&P and "Patrick" told me that I need to 1) unplug the machine, 2) tilt up the front of the machine, 3) spin the pump (plastic blades) until they turn freely (usually counter clockwise) but I turn it both ways till it turns freely, 4) plug the machine back in and press the buttons to get it back where it was - this has worked every time to get the machine going again. I do a lot of "dog laundry" and I'm sure the rugs/dog hair cause the problem. Hope this helps!
Anonymous
  • 17 Answers
  • Posted on Apr 19, 2009
SOURCE: fisher paykel smartdrive 601
Most likely a blocked pump
Anonymous
  • Posted on Oct 04, 2009
SOURCE: I have a fisher paykel ecosmart wash cycle but when
Tip the Washer and check the hoses.... my husband just found 2 pennies stuck in one of the hoses in my F&P GWL15
My Fisher and Paykel washer is leaking water from bottom back right side in the rinse cycle. Any thoughts?
Question edited to correct name of maker, (Fisher PayPal :>)
Question moved to one of their categories.
No clue to whether a top loader or a front loader, which is why we ask for full 'make model (what it is)'.
If it is only in the rinse cycle, and if it is a front loader it is likely to be spray of a crack in the box that is the detergent drawer and fabric softener mixer. The only way to find out is to remove the top after a wash and look for where the water came from.
Some other ideas here
https://www.google.com/search?q=Fisher+and+Paykel+washer+is+leaking+water+from+bottom+back+right+side
Elba washing maching wa65tm stops at rinse
have u got a rinse hold switched on.this is to keep clothes from getting creases it holds until someone tells it to complete cyle
My fisher & paykel washer will not move to rinse cycle
Fisher & Paykel GW712 AU 93200-A STOPS @ THE RINSE CYCLE & THE SPIN CYCLE?
Questions on use of softener and detergent
softener goes in agitator cap. when machine does first rinse and spin it will dispence.i dont think so 4 detergent use, front loader detergent doesnt froth as much.see how u go and reply 4 more help
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Fisher Paykel GWL11 Top Loader Washer
Please dont put any more money into this machine,if you wait long enough it will take alot more than a penny.
Kenmore Front Loader stuck in "LOC" and every button produces "ERR"
Look for the 2 buttons on your that have a lock symbol.  Pushing & hold both for 3 seconds.  This toggles the child proof mode.
Top Fisher and Paykel Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
