Toro Blowers Rake and Vac - Electric Blower/Vac - 51573 Logo
Posted on Jan 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Toro 524 with Tecumseh engine, model 38040 8 0000640. I am rebuilding the carb and would like to know what are basic settings for idle and hi/low speed screws?
Roy Cagle
Level 3:
President:
  • Toro Master 1,545 Answers
  • Posted on Jan 15, 2011
Roy Cagle
Toro Master
Level 3:
President:
Answers
1545
Questions
Helped
913502
Points
4781
The high speed mixture screw is initially set at 1 & 1/2 turns out. Then adjust it to give good acceleration and top speed, while not closing the screw more than you need to. The low speed mixture screw is set at 3/4 of a turn out. Adjust that, to give a smooth idle. The 3rd screw, the idle speed screw, is set to give a low idle speed without stalling.
I have a Tecumseh 5.5 Enduro Power Washer and need a replacement carb for it.
If the carb is still intact, you may just want to rebuild it. Parts are easy to find and inexpensive.
1helpful
Toro lawnmower model 20027. The engine starts fine, but goes to full rpms. I have closed the throttle with my finger but it goes back to full rpm operation. Everything seems fine on the mower. i just got...
"Most likely you'll have to remove the bowl nut, under the carb's bowl. You'll most likely find varnish in the jet, or maybe water. These are some typical jets, Tecumseh. Briggs, similar" (baymee LehighValleyPA, 2009).
I'm going to try this tomorrow myself!
2helpful
Toro recycler 20017 is very hard to start. it has to be primed many times. after it run a while it starts on one pull.
The carburetor may need to be serviced. You need to find a parts shop that handles Tecumseh parts. You will most likely need a rebuild kit for the carburetor. The carburetor part number is 640303. The rebuild kit is 632809. The Tecumseh engine company shut its' doors 3 years ago. Finding parts is becoming harder and harder. I've heard that someone has bought Tecumseh over the winter but it is unknown when the new parts will hit the market. Best of luck to you.
Replacing a tecumseh carburetor on a toro
PartsTreeRepairClinic may have a video
Jan 30, 2018 • Toro Garden
How to set up a carb with 31840 rebuild kit
what exactly do you want to know? Carb. mixture settings are as follows: L-head engines
Tecumseh carbs.........mainscrew 1 3/4 turns idle screw 1 1/4 turns
Walboro carbs........... mainscrew 1 1/2 turns idle screw 1 1/4 turns
L-head and OHV heavy duty engines 1 turns for both
Dec 21, 2009 • Toro Garden
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
