SOURCE: hotpoint aquarius 1000 deluxe W22 washing machine
the newer type motors have carbons tht are fixed in place you would need to remove the motor and on either side will be the carbons they need to be un-screwed to be replaced
SOURCE: How to remove top panel and front facia on a Hotpoint Aquarius WDF451 washing machine
Un plug it. There should be small screws either at the bottom of the panel on the front or there is separate panel that comes off the top back. If the back is one solid piece top to bottom, then the control panel lifts out and hinges up when the two small cross tip screws are removed from the bottom outside corners of the control panel..
SOURCE: My Hotpoint Aquarius plus 1400
Your inlet valve at behind top of machine is defective; or the pressure from your faucet is insufficient.
Close your faucet valve on wall & unscrew your hoses to check screens on hoses & machine. Clean out well. See that the water pressure is good. Refit, check for leaks. If this is not the problem change your inlet valve, it is easily done.
Sites for spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Pl rate if helped.............
SOURCE: hotpoint aquarius washing machine water
Hi, Ok first things first where is your machines waste pipe connected? If it connected to the sink trap check there first by undoing it and check that there is nothing inside stopping it from letting the water out..?
If this is clear then have you lost anything? Sock? ETC....? Can you hear the pump? And is the water draining but not spinning?
If you cannot hear the pump running then it will more that likely be the pump as they are a magnetic pump which fail quite alot. If the pump is running then it is going to be something you have lost which will be located in the sump hose underneath the machine whic comes from the tub to the pump. Take it off and check and clean as nesscerary. Or last but not least it could be the fact it is doing everything but not spinning ( no drum action )? Check the motor carbon brushes if they are low then this will cause the problem or the motor has failed!....
Good luck and let me know ho you get on??
SOURCE: Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
Try unplugging the unit and plug it back in. This may reset the controls.
