Hi, sometimes if multiple buttons on a remote are pressed at the same time, the remote will try and send both codes and the unit it is designed to control won't respond because it doesn't recognize the signal. Those signals are usually sent no matter what button is pressed after until you do a reboot on the remote. You can go here to find the reboot instructions: https://www.remotes.com/Articles.asp?ID=273
SOURCE: code for sky remote control for LG 42LT75 LCD TV
the remote i had was rev 6 control and i tried every number going but no luck.
i then ordered new remote control which is rev 8(you can find this when you open the battery lid)
and i typed in 0206 and it worked(bingo).
good luck
SOURCE: sky remote control code for LG tv
Can you provide me with a set up code for my Sky remote control to work my LG LCD tv model no. 32LG3000?
Many thanks
SOURCE: Code for sky + remote to operate bose cinemate volume via the sky remote ?
1356 something like that ;)
SOURCE: what code do I use to set up my sky hd remote to
With you sky remote follow the steps below:
TV
RED + SELECT ( flashes twice )
TV
0051
now try the volume button. If this works then press SELECT to save. If not press TV and then volume again. Repeat this step until the volume works then dont forget to press the SELECT button to store the code.
Job Done. Please leave a thumbs
Cheers
Little Dish Fitter
