Televison & Video Logo
Thabiso Kobo Posted on Jan 06, 2011
No signal from dstv decoder to coax.cable,but it shows scanning on tv monitor.
  • 2 more comments
  • Anonymous Mar 13, 2014
    my dstv is just shows scanning on the tv but does not play
  • Anonymous Mar 19, 2014
    audio cable to dstv decorder
  • franciscovinganco
    franciscovinganco May 12, 2014
  • franciscovinganco
    no signal my decoder PVR 3001 is just shows scanning on the tv but does not playAdd a Comment
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 20, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3264
Points
30
No signal for dstv for my decorder pls help me.
Anonymous
Level 1:
New Friend:
  • Posted on May 10, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3264
Points
5
I HAVE A DECODER OF DSTV, BUT THE IT SHOW RED, ORANG AND GREEN LIGHT CONSTAND. AND THERE IS NO PIC ON THE SCREEN.
Aim 60 Inch Digital UHD. There is no sound from my dstv HDMI connection only, picture is fine, decoder tested by dstv fine, other HDMI inputs work fine, I know the HDMI cables are fine. please assist.
If you're not getting any sound from your DSTV decoder when connected to your Aim 60 Inch Digital UHD TV via HDMI, there are a few things you can try:
  1. Check your TV settings: Make sure that your TV's audio settings are set correctly. Check that the volume is turned up and that the TV speakers are not muted or turned off. Also, make sure that the TV is set to receive audio through the HDMI input.
  2. Check your DSTV settings: Make sure that your DSTV decoder is set to output audio through the HDMI connection. You can usually check this in the settings menu on the decoder.
  3. Try a different HDMI input: If you have other HDMI inputs on your TV, try connecting the DSTV decoder to a different one to see if the problem persists. This will help to narrow down whether the issue is with the HDMI input on your TV or with the DSTV decoder.
  4. Try a different HDMI cable: Even if you think your HDMI cable is fine, it's possible that there is an issue with it that is causing the sound problem. Try a different HDMI cable to see if that resolves the issue.
If none of these steps solve the issue, it's possible that there is a problem with the HDMI input on your TV. In that case, you may need to contact Aim customer support for further assistance or consider bringing the TV to a repair shop.
Solid yellow light on my dsd 3u decoder, how to fix?
Power fluctuations
https://www.askmefast.com/MY_DSTV_DSD_3U_DECODER_IS_DISPLAYING_ONLY_ORANGE_STEADY_LIGHT-qna9330642.html
Or it might be dad service, or downloading new software
[Responded] Poor service / Decoder software removed ' DStv ...
www.hellopeter.com > dstv-multichoice > reviews > po...
Mar 14, 2018 - However, the problem escalated now whereby my DSD 3U DSTV decoder suddenly switched off and only display an amber light in the middle ...
Gotv decoder showing a yellow / Orange light constantly
myofflinestash.com > index.php > gotv-decoder-showi...
Solid Red This means that the decoder is in StandBy Mode, this is similar to a computer being put in sleep mode. · Solid Amber This state of the decoder means ...
Quick Guide - DStv
cdn.dstv.com > selfservice > documentation
PDF The moment you connect your DStv HD Decoder, is the moment your TV viewing experience will become ... Solid AMBER = decoder is downloading software.
My dstv is not showing infomation on channels is blank on channels info please help
Try this qiuck solution as it works most of the time:
Switch off your DSTV Decoder or Unplug power supply cable at rear of Decoder.
Remove your Sim card and wait 90 seconds.
Switch your DSTV Decoder back on or plug Power supply cable back in at the rear of your Decoder.
Enter your Sim card and wait for your Decoder to re-scan (about 2 - 3 minutes).
Dec 12, 2018 • Music
2answers
Dish Satellite recently installed in my home supporting several tvs. MY JVC TV model LT32E478, designated as TV1, does not recognize any channels during program scanning. As a result, the timer on/off...
Hi mfaille
I`m going to help you with your setup but first;
Which connection are you using from the sat receiver to the tv?
Coax / standard rg6 cable?
Did you try to manually add(in the menu/tuner setup/find channel/add) the channel you need ?
1helpful
Decoder keep scanning
well, firstly. u have a sat finder!! great!! now lets see if i can teach u how to use it, when you hook it up there will always be some sort of signal, (other electronic waves in the air) the best way to check is to put ur hand in front of the LNB (the square box in front of the dish) if he signal goes down, the signal was fine to begin with, if it goes up, the dish is out, if nothing happens... dead LNB, which in my experiance, the most likely cause, dont for get to reset your decoder once you have solved the problem.. good luck
I have my cable coax connected to the UHF, VHF, CATV input. If I connect cable to Digital Antenna In input and do channel search will I receive local digiatal broadcasts or do I need to split the coax to...
You need to put a compatible cable decoder box between the cable and TV as the sanyo will only decode analogue cable signals via the catv UHF vhf input
the digital antenna in is for digital air broadcasting signals only
3helpful
Need to connect my DSTV decoder through my sony amplifier (5.1) not sure of a the cabling or the connections, does someone perhaps ahve a wiring diagram to connect TV, dstv decoder and sony 5.1 amplifier?...
well this is easier than you think, get yourself a set of RCA's (the red and white and yellow cables that DVD players come with) look behind your decoder and place them colour to colour, then behind your Amp you will read (TV IN) do the same, then with just one yellow RCA plug it into (monitor) that one will then go to the (AV input) behind your TV.. And presto!!! now set your amp input on the remote to TV and your off!! good luck
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
