The new one goes in the same as the old one comes out. You have 2 screws on the bottom of the evaporator that holds the sensor in place. Then the sensor runs thru the bottom toward the back.As you remove the old one jus put the new one in the same way.
This is actually the easy part....;-) On mine... I had to remove all of the shelves (5) which slid out just like my kitchen cabinet drawers. Next I removed 4 screws that held on the cooling coil assembly (Big white smooth flat piece with raised ridges running through it.). Once the screws were removed, I carefully lifted the cooling coil assembly/panel until I could see the old whip and pig tail. (Sorry I am going on memory here...) I believe that there was another screw that held the end in place that I had to remove and then reattach to the new whip once inserted through the back and snaked into place. Really I remember this taking only about 10 minutes to do start to finish. I reused all of the "filler" stuff to reseal the new whip in place.
Haven't seen yours but most models have a tube you slide the probe up into. Did yo not see that when you removed the old control?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
no tube. The thermastat is in front at bottom. The coil goes underneath and then up the back on outside of insulation. But then it goes into the insulation through a hole in the insulation that is now filled with a putty. After removing the putty, you can see the coil go in behind the insulation where it is probably attached to teh evaporator.
very helpful. it was staring me in the face and I could not figure it out. The expert put in the right track.
