SOURCE: Bachmann HO train set not working
I realized that you can't use two left hand turnouts because they end up making a short when the come full circle!
SOURCE: transmitter power lite is on but no power seen at engine-
There are two switches at the rear of the engine. One turns the sound on and off and the other turns the power to the engine on and off. Make sure you have the power switch turned on. It should default to full forward with the transmitter off.
SOURCE: WE have just gotten my
The batteries are located in the enginge (locomotive). They take 6 D sized batteries. At the very back there is a panel that you need to slide off to get to the battery compartment. Somtimes it may take a little manipulation to get the panel open.
SOURCE: MY R/C TRANSMITTER # 90-0100-A27
Hi Jiggs,
Double check the batteries with a tester. I've gotten them drained off the shelf. They do have expiration dates.
Make sure the battery connects and springs are clean and shiny, free of corrosion.
Next, make sure they are put back in the right direction. I know, but it happens. Check anyway.
Make sure both units are powered on.
That's the easy stuff.
Next step requires making sure the leads to the antennas are tight and free of corrosion.
If the set is new, Do not open anything as this will void the warranty. Bring it back for exchange.
Best regards
Mike
