Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
Posted on Dec 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I replace the boot on my bosch WFMC6600UC washer? It has a tear and is leaking.
Barrett Palumbo
Level 2:
  • Expert 1,772 Answers
  • Posted on Dec 19, 2010
Barrett Palumbo
Expert
Level 2:
Answers
1772
Questions
0
Helped
502209
Points
289
Very hard to replace boot, entire machine has to come apart. 2nd it takes experience to replace a boot, 3rd the boot will cost 150.00 to 250.00.
have a tech do it
2answers
Leaks left side underneath..only on rinse cycle
You can download the user manual at: http://lesepc.com/uploads/b/bosch-classixx-wfl-2066-manual.pdf
Water leak out the bottom of the door when it running door seam lose
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Manufacturer Part Number 4986ER0004G
1helpful
Water leaking from Bosch washer
Hi check the grey rubber seal around the door to the washer if there's a rip or tear if there is that would be the problem if not check pipes going to pump also water feed etc make sure all on and tight
Leak in front
see this steps and fix it. God bless you
Drain Pump
If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. The tub bearing often gets damaged when the seal leaks. consider replacing the tub bearing along with the tub seal.
Tub Spin Seal
If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. When the tub seal fails water gets into the tub bearings and usually causes the bearings to go bad also. It is a good idea to replace the tub bearings with the new tub seal.
Door Boot Seal
Tub to Pump Hose
If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose
If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose
If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
2answers
Water leaks apparently from a tear in the circular seal next to the door
This video will show you how to change a door seal on this Bosch front loader washing machine
we have all bosch repairs in our channel
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
1helpful
2answers
Front seal leaking in my bosch exxcel 1200
This video will show you how to change a door seal on this bosch bosch exxcel 1200
Water leaking in front of washer mainly from what seems to be the gasket around front of washer.
Either the rubber boot is damaged in some way, or the door is not locking tight enough. Thoroughly inspect the boot for tears or gouges in the rubber surface. Small imperfections can be repaired with silicon glue, but larger tears will require replacement of the boot--which can be done done through the door opening, but requires patience to do so. Inspect the door lock for damage or wear if the boot looks to be in good condition.
Bosch WFR2460 Leaks
are you sure it only happens in the spin cycle? and is the leak comming from the bottom front of the washer? most front laoders will leak due to a tear in the belows. that is the rubber boot that seals the washer tub to the front panel. if there was a hole or a tear in the bellows it should have a leak inthe wash cycle also. but there are also other possibilitys too.but its strange to only leak in a spin cycle due to the washer is extracting the water and not adding it. so check and see if it leaks in the wash cycle to and get back to me and we can go from there. looking through my training manual i dont see what could cause a leak in just the spin cycle
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
