Pls help! I live in South Africa and have a LG RH1757 HDD / DVD Recorder and it won't play region 1 DVD. Is there a code I can use to change this?
Thanks
Mark
Does the same solution (Set-up, scroll to lock, press 0 seven times) work for all LG DVD/HDD recorders? I am thinking of buying an LG RH387H in Macau and want to know if it will still work when I return to Australia. I couldn't find this model in the list!
I just got a RH387H in Hong Kong, region 3, but the above method doesn't work, this model has slightly different icon, no "lock" icon, I tried in other similar location but no effect, hopefully someone will provide a method.
ipw
Hi I got a Lg HDD/Dvd Recorder Model RH1999H. Ihave a problem copying Dvd from the hardrive. When I load a completly blank disc, the recorder will not intialize the disc. How do get this recorder to intialize the disc to video. When i got to set up mode, I select Disc Format option, i cannot get into the format mode, I tried to change it but it does not change the only thing I see on the disc format mode is PBC highlighted.
Please advise
AmarE-mail [email protected]
cannot play region 1 discs on my region2 machine. codes?
cannot play region 1 discs on my region 2 machine
