SOURCE: ice build up
Check that the door is closing properly otherwise the freezer will be working overtime to cool and ice will form. If the door seal is good, it is possible that the thermostat needs to be checked.
SOURCE: freezer/fridge radiator keeps icing up.
The problem is most likely either the defrost timer, and/or the defrost heater element(s) are faulty. The problem is that the defrost heater elements are not functioning properly and the evaporator core is actually freezing up and blocking the air flow through the evaporator core and also freezing up the thermal sensor, and when that happens there is no longer enough cold air being circulated through the refrigerator (that is actually how the unit operates and air must be able to flow through the evaporator core and then be circulated throughout the refrigerator to properly function) and as a result the refrigerator stops functioning and food can even thaw out in the freezer although the freezer seems to be iced up. (Usually at the rear wall where the evaporator core is located)
(Air flow through the evaporator core and cold air circulation and re-circulation through the refrigerator is performed by the air circulation fan and it also must be functioning)
Be sure to only use a blow dryer (with a towel on the bottom of the freezer) to thaw out the evaporator core and do not use any hard or sharp objects or the evaporator core can be damaged. The defrost timer can be located inside of the refrigerator itself, (see lower image) or it can be mounted outside usually either behind the air intake cowl at the front base of the refrigerator, or most likely located behind the service panel on the rear of the refrigerator, and usually if the defrost timer is turning then it is most likely working, however the defrost timer can move very slowly and you can place a mark on the timer and the housing to check after about fifteen minutes to see if the position on the defrost timer has changed.
Here are some images that should be similar to your situation to help assist you, and let me know if you require any further assistance.
Other Beko branded models and all Beko frost free fridge freezers manufactured after this date are unaffected.
Affected model numbers:
