Try this:
To set time and date:
1) With time and date showing, press SET.
2) Seconds ?ash. Press START/STOP to round time to nearest minute,
setting seconds to zero.
3) Press MODE. Hour ?ashes. Press START/STOP to change hour,
including AM (no symbol) and PM.
4) Press MODE. Minutes ?ash. Press START/STOP to change minutes;
hold button to scan values.
5) Press MODE. Month ?ashes. Press START/STOP to change month.
6) Press MODE. Date ?ashes. Press START/STOP to change date.
7) Press MODE. Day ?ashes. Press START/STOP to change day.
8) Press MODE. Time format ?ashes. Press START/STOP to select
12- or 24-hour time format. 12-hour format has AM/PM.
9) Press SET, at any step, to exit and save settings.
Date (day of month) appears in upper part of display in Time mode.
Press and hold START/STOP to see month and date in large digits.
SOURCE: i need to adjust Timex
Go to the time mode,hold down the set button, it may take a couple of seconds and it will start blinking , then go to your mode button to move from seconds to hour to min etc.etc,etc. It probibly is your start/stop button for chaning the numbers. If that dosn't work, hold down the mode button on the time mode for a few seconds, and go from there.
SOURCE: Have a 1440 Timex Sports Indiglo watch. Just want
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals.Rate me, please
SOURCE: timex 1440 sport indiglo 50m
There are several models of your watch not all of which appear to have a 12/24 hour display format.
Try this extract from a manual; press the MODE button six times to enter the 12/24 adjusting setting and then use the START/STOP or SPLIT/RESET button to change the time.
Press the mode button to return to normal operation.
SOURCE: Trying to set time on Timex 1440 sport with mode
press and hold the mode button until the digits blinks then press it again once, (digit that are blinking is changeable) use the "start/stop button to choose what will you change and adjust buttton to adjust it. if your done, press the mode button again once.
i hope i had been helped you.
