One not way would be to define a 4x4 matrix Mat A to hold the coefficients of the linear system. Then define a 4x1 column vector Mat V to hold the constants on the right.
Define a third 4x4 matrix Mat B you may leave filled with 0.
On command line, in Run Mat screen enter (Mat A) ^(-1) and store it in the zero-filled matrix Mat B. this is the inverse of Mat A.
If the inverse of Mat A exists, and it does in this case, the solution of the system is obtained as the column vector, resulting from the multiplication of Mat B by column vector Mat V
You can even shorten the procedure by just calculating ((Mat A)^-1)X (Mat V) [EXE]
To summarize
To get the Mat identifier on command line,
To calculate the inverse of the matrix just use the [SHIFT][)] key sequence which is (X^-1)
Multiplication operator is the regular [times] key.
See images below
