Watches Logo
Posted on Nov 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a watch 0606092 movado and i cant pull out the crown to set the time, please i need help, how do I do it?
Arturs Kalnins
Level 3:
  • Master 2,338 Answers
  • Posted on Nov 15, 2010
Arturs Kalnins
Master
Level 3:
Answers
2338
Questions
9
Helped
1813034
Points
13579
Your watch may have screw down crown, so, you have to unscrew it first, then you can pull it for adjustment.
8helpful
I just recieved my Movado 800 series watch today and the large chronograph timer hand won't reset to zero (top of dial @ 12 o'clock) when I press the zero button. It resets to 56 minute position....
you do not need to return, as this is re-settable. Pull out crown to the first position (date setting) and then toggle with upper push button. If upper button do not do the job, try the bottom one. When you reach 12, then push the crown back in. Start the chrono, stop it and check if it returns to 12.
Cant set wrist watch
To set a basic wristwatch, simply pull the crown (the winder button at the 3:00 position on 99% of watches) out gently - it will click into adjusting position. Wind to send time and then push back in again.
Variations on this are: If you have a watch with date display, the crown will have 2 positions, the first click will be to set the date and the second click (fully out) is to set time. If you need to adjust the date, I suggest you wind the date to the day before you need and then use the second click to wind the hands to the correct date. This way you will be able to know if you have the hour at a.m or p.m position and avoid it have the date changing during the day instead of at night.
One last variation for wristwatches is a screw down crown. Some water resistant and sports models incorporate an added feature whereby the crown is threaded so it can be tightened down to avoid water entering - the most common place water gets into a watch! If you have one of these, you simply need to screw the crown anticlockwise until it pops out and then refer to the instructions above. Don't forget to push and screw the crown back in clockwise when you are done
The chronograph hour hand on my movado series 800 is out of sync and i cant get it back to the 0 position. I have pulled out the crown and pushed the start/stop button...
Try pulling the crown out and using the reset button to move hands beside the sweep arm. If this doesn't work then you may need to take it to a repair shop that can reset or AC the watch. With a movement as fine as Movado I wouldn't attempt this yourself. If you make a mistake the repair could cost more than the watch. Be sure that you have the watch resealed so it maintains its water resistance.
I have a Movado series 800 model 2600075 watch. I lost the manual and now need to change the time setting. How do I do that? Thx.
Turn the crown of the watch towards you until it pops out... After the crown pops out, pull on it to extend fully and you should be able to change the time at that point.
6helpful
How do you set the time
Turn the crown of the watch towards you until it pops out... After the crown pops out, pull on the crown to extend fully and you should be able to change the time at that point
In reading the movado 800 quartz chronographic instruction manuel there are 3 settings for the crown. the first is the one in which you generally wear it. the second position states it will stop the watch...
The time should only stop when the crown is pulled all the way out in the third positiion... In the second position the 2nd hang should continue to tick and you should only be able to move the hour hand on the watch
7helpful
How do u you set the date on movado series 800 steel watch
How to set the clock how do i no the battery good just got it
If the watch is not running it's probably the battery. To set, pull the crown out and turn to adjust the time. Push the crown in to run the watch. If the watch is new the battery should be OK but take it back to the store if it doesn't run. If you bought it used take it to any watch shop for a battery replacement. Sears does it for about $8 or less.
4helpful
I cannot push the "winder" all the way beack into my Movado
push crown in and turn while pushing in turn the crown away from you.... The crown will then screw into the watch
Top Movado Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Movado Watch Expert? Answer questions, earn points and help others
