Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Nov 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i reset front panel on my whirlpool washer front load duet
Anonymous
Level 3:
  • Whirlpool Master 1,902 Answers
  • Posted on Nov 10, 2010
Anonymous
Whirlpool Master
Level 3:
Answers
1902
Questions
0
Helped
533838
Points
5669
Hi
Its a simple procedure to reset the Whirlpool Duet front load. Please press and hold the END OF CYCLE button for 15 seconds to reset. Please get back to me if you have any other questions.
Kevin
  • Shortstoryyo Mar 05, 2012
    I'm a tec I do autobody and I fix everything eventually I Tryed everything on my washer but the end of cycle button. thank u your the man !
  • Shirley Shewchuk
    Shirley Shewchuk Feb 12, 2019
    My machine is model WFW9250WW01. How do I reset it?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 23, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5698
Points
Can't get heat to go on on whirlpool duet
5 Related Answers
Anonymous
  • Posted on Jul 16, 2009
SOURCE: Need to reset whirlpool duet front load washer
How do I reset a front loader Whirlpool washing machine. The time keeps flashing. I drained the washer and now I need to reset it.
Anonymous
  • 1902 Answers
  • Posted on Feb 13, 2009
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Anonymous
  • Posted on May 17, 2010
SOURCE: Help with Model #GHW9400SU0 Whirlpool Duet Front Load Washer
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED status light turns off.
Anonymous
  • 212 Answers
  • Posted on Jun 22, 2009
SOURCE: whirlpool duet front load washer has standing water inside
take off bottom panel of washer. unscrew front plug to drain pump. clean out
Anonymous
  • Posted on Jun 25, 2009
SOURCE: My Whirlpool Duet Washer, model number WFW9400SW01 will not turn on. The button lock is off and does light up indicating power to the front panel/unit. Any ideas?
I had the same problem. Inside the door there is a little black button that sends a signal to the panel telling it that the door is closed so that it will allow the washer to start. Mine broke off. I did my own fix it by using foil to fill the hole holding the button in permanently, then taped it. I will eventually get some superglue and glue the black piece back on. But my washer is working again. ( This was only discovered after I took it all apart, because i thought it was in the "start" button.
1helpful
How do i reset a duet whirlpool. GHW9400PL2
On the Whirlpool Duet washer, try pressing and holding the End of Cycle signal button (on the far right of the control panel) for 3+ seconds to toggle the Control Lock on/off. See the manual here: https://www.manualslib.com/manual/193849/Whirlpool-Duet-Front-Load-Washer.html?page=10#manual and here: https://www.manualslib.com/manual/193849/Whirlpool-Duet-Front-Load-Washer.html?page=12#manual . The small print about the Control Lock is almost readable (with good eyesight/correction) in the control panel closeup of the GHW9400PL here: https://www.ajmadison.com/cgi-bin/ajmadison/GHW9400PL.html .
I hope this helps.
(When you turn off the washer, it will remember the last setting for the Control Lock. This ensures that the washer can't be accidentally started by a child or while you clean the control panel.)
29helpful
2answers
Describe your Whirlpool Duet GHW9150P Front Load Washer Problem the control lock button is on
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washer however; your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
The control panel is locked.
This is a common issue with Whirlpool Duet washer however, your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE /CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
1helpful
Duet GHW9150P Front Load Washer: The control lock light is lit on my whirlpool duet...
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
3helpful
Whirlpool duet front load washer has standing water inside
27helpful
Whirlpool Duet Washer 'Control Locked'
Press cancel or if that doesn't work unplug the washer from the main socket - this should clear all the settings so that you can reset the washer.
Bev K
On whirlpool duet ,am getting fault code f21 in wash cycle.
Foreign objects in the prepump
remove access panel in front remove round plastic plug clear objects have towels ready
1helpful
Whirlpool duet ht wouldn't start
remove the lower front panel,3 screws,side up and off,there is a tech sheet inside on the panel that should help you ,let me know what you find-mike
3helpful
2answers
Duet front load washer control locked--How do I undo??
2. Remove the lower kick panel.
3. Reach up along the inside of the front and locate the bottom
of the door switch/lock unit.
4. Located on the bottom of the door switch/lock unit is a
tear-drop shaped tab.
5. Gently pull the tab down about a ¼" or until a click is heard
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
