Fisher E522BLX Stainless Steel Logo
Posted on Jun 13, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fisher & Paykel Model number 402B S.Steel. Bottom frezer top Fridge.
My Fisher & Paykel Model E402B Stainless Steel Fridge/Freezer has a problem. Bottom Freezer is OK but Refrigerator will not work properly, somtimes it will freeze everything, other times it wont ? A beeping alarm comes on every few hours and we have to reset the buttons.What is the Problem?.
  • 15 more comments
  • dcneedham Aug 08, 2008
    Same problem
  • Anonymous Aug 09, 2008
    I'm having the same problem. I have had a look at the fan at the back of the freezer and it looks like its not working. I'll replace it a see if this fixes the prob.
  • Anonymous Sep 05, 2008
    same issue I will check the fan loock very easy fix thank
  • kreis2008 Oct 03, 2008
    i have had the sensor replaced now the circuit board and still the problem is not solved. very frustrating. fridge doesnt cool, freezer works fine, beeping is totally annoying!
  • Bruce Wilmot Oct 07, 2008
    Fisher E522B - Basically problem started when the freezer started to ice up; first symptom
    was half inch thick slab of ice on freezer floor. I defrosted, and for afew
    weeks OK, but similar thing happened. Thought the kids were leaving the door
    open when getting ice etc. Also the were ise crystals forming on side of
    freezer and at back near fan. When heavily frozen up, no cold air getting to
    fridge. Could it be defrost program or as others mention the Fan?
  • Anonymous May 26, 2009
    I have a fisher & paykel e402b fridge freezer. The fan recently packed up and was replaced, however the fan is still not working. Is there any cause for the fan not working? wires are not broken...freezer is working, just not pushing cold air around the fridge
  • Anonymous Aug 03, 2013
    I have the same problem too!! I defrosted everything in freezer as door wasn't able to shut then when i put it together again constantly beeps please let me know what you did if you managed anytying?
  • Anonymous Mar 12, 2014
    fisher and paykel model C410B
    fridge is beeping after water leaking from freezer
  • Anonymous Mar 16, 2014
    like I said I open the fridge door, it beeps twice and now it will vibrate as well it flashes on the back panel,will not regulate itself
  • Anonymous Mar 24, 2014
    The fan in freezer won't turn off
    The fan in the freezer runs continually will not shut down. Liquid on top shelf of refrigerator freezes.
    Fridge on top freezer on bottom. Fisher paykel.
  • Anonymous Mar 25, 2014
    LCD panel in water dispenser does not work and not water comes out
  • Anonymous Mar 28, 2014
    stopped working
    I am having trouble understanding how this fan can be removed from the rear pannels
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 29, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2945
Points
My Fisher & Paykel Model E402B Stainless Steel Fridge/Freezer has a problem. Bottom Freezer is OK but Refrigerator will not work properly, somtimes it will freeze everything now it just warm inside i have checked the the fan and the rubber holding it up has broken also the ice is frozen in the vents can you help i got someone in to fix it but he said it will cost around $600 as there might be more wrong with it, what do you suggest thanks Clare
Brian Coughlan
Level 2:
Champion:
  • Expert 280 Answers
  • Posted on Nov 30, 2011
Brian Coughlan
Expert
Level 2:
Champion:
Answers
280
Questions
0
Helped
87035
Points
430
A
Anonymous
Suggest calling fisher & paykel as I called them for similar problem and cost me around $190 for one of there techs to fix and 12 month warranty.still working month later.
E402b beeps once every 5 minutes
It's alerting you to a fault, maybe a fan or a heater element etc. Call F&P customer care.
E402B model alarm comes on every 6 to 8 hours. fridge not cooling we have to reset it why?
ck the fans under neath and clean the coils as this the most common for your problem. . also ck the fan in freezer . it runs when the compressor is working . and if it not not enough cold .. ****
4helpful
Fisher & Paykel active smart fridge keeps beeping for no apparent reason, while door closed
press the select button ( the button that you choose the temperature on the fridge and freezer) and check that the fan on both fridge and freezer are working.
9helpful
2answers
Fisher & Paykel Fridge Freezer E402B beeping when door closed
If the cabinet is warm inside it is a failed circulation fan, failed defrost causing the evaporator to freeze up, or it needs a refrigerant gas top up.
Beeping is just an alarm. It may be because of the more serious issues listed above but can also be caused by a failing door gasket, the door being left ajar (kids are famous for this) or the door has been left open too long deciding what to have for dinner.
I hope that answers all 8 of you :>D
Help here
https://www.google.com/search?q=fisher+and+paykel+fridge+beeping+with+door+shut
1helpful
3answers
1helpful
2answers
Uneven cooling in fridge and annooying alarm every 10 hours!
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Top Fisher Refrigerators Experts
Mike Cairns
Mike Cairns
ADMIN Eric
ADMIN Eric
The Claw
The Claw
Level 1 Expert
Are you a Fisher Refrigerator Expert? Answer questions, earn points and help others
