Nice content to read. <a rel='nofollow' href="http://marktechnologies.in/">Visit Us Here </a>
The photo shows the master 'smart' dimmer, but you purchased the remote 'smart' dimmer that is slave to the master dimmer.
So you are correct, that is not the correct dimmer for a single-pole application.
Cooper brand Aspire dimmers are available in 'Smart' dimmer and just plain old dimmer.
Smarthome has a plain old aspire dimmer
http://www.smarthome.com/21530S/Aspire-9530DS-600w-Slide-Dimmer-Desert-Sand/p.aspx
Google products also shows the Lutro Maestro dimmer
http://www.google.com/products/catalog?q=maestro+dimmer
Lowes and Home Depot have ordinary dimmers also.
Both the dimmer linked to above will work for your single pole application. Keep in mind, they also work for 3-way applications so there will be an extra wire.
Since you know the phrase 'single pole' I suspect the wiring for you will be a cinch.
If you need assistance with the new dimmer, add a comment and I will answer.
I am wiring up my custom yurt home I built, and my friend is a very experienced. He I have the master dimmer I bought from Lowes, same model as this, however I did not see a dimmer labeled as a slave. He believes that the slave have different wires out the back and we need a slave. I also bought the same brand name, standard dimmers.... they have the two screw ins from the side. will they work as slaves? or can the master dimmer work as a slave to, as I didn't see any slave for sale at Lowe's.
