SOURCE: programming channels
Hey abshee,
In order to program the channels for this TV, you'll want to press the "Menu" button on the TV itself. Once in the main menu, scroll down until you see an option called "Setup." From here, press the right arrow key to enter the submenu. Before going any further, you'll want to make sure that the tuning band is correctly set to "Air" or "Cable," which will depend on how you have your TV connected.
Once the proper input has been selected, you can then scroll down to "Auto Ch Search." If you press the right arrow key on this option, your TV will automatically search for all available channels.
If you'd like step-by-step instructions (with pictures of what you should see at any given step), I'd suggest checking out the link I've provided below to Insignia's online owner’s manual for this model:
http://www.insignia-products.com/skins/skin_1/Topics/Documents/NS-LCD22_press.pdf
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
SOURCE: Insignia TV no audio on non HD channels via HDMI cable.
have you tried to change the audio settings to HDMI on tv? when u have HDMI hookd up u have to change the audio to HDMI also
SOURCE: No digital channels
Testimonial: "Thanks. I resolved it by removing a splitter from being in line with the cable itself."
SOURCE: tv picture looks grainy like it was shot on video
well most lcd and plasma tv's above 36" will look grainy on standard definition because they are made for high definition so if you do not receive a high definition signal to your tv then that would most likely be the problem
