SOURCE: kodak easyshare c533 blurry LCD
try upgrading the firmware of your camera. You may download the firmware for free at www.kodak.com/go/downloads
SOURCE: Kodak EASYSHARE M1063 won't turn on
For this problem try doing the following:
If problem persist call the 18002356325 for technical support for KODAK Digital cameras
Thanks
Hope this will help
SOURCE: My Kodak EASYSHARE M1063 camera won't turn on
Remove the memory card and the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
SOURCE: kodak easyshare c643 - batteries are fresh, but it
If the camera has recently been dropped you may have lens damage that is preventing it from powering up. If it hasn't been dropped your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Testimonial: "Thanks for the help!"
