Between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Swan fridge freezer not working
Dirty coils underneath the fridge, or the fan in the bottom (to cool the compressor) is not working.
SOURCE: my side by side kenmore refrigerator, freezer isnt freezing
in the back of the freezer there is an "evaporator coil" .. that has many fine fins and is used to cool the air .. you dont normally see it because there is a panel bolted over it ... if the door was left ajar for awhile then ice forms on the evaporator and stops air from flowing thru it ... the result is that it cant cool the freezer properly ... if this is the problem then you can fix it by taking everything out ( use an insulated tote to store things or use a neighbors frig overnight .... turn your refrigerator off or unplug it ... open both doors and let it thaw out for a day or overnight ... put down towells to collect the melting ice .. you can even blow warm air into the bottom of the freezer to make it thaw faster but be careful not to overheat plastic parts .. once the unit is completely free of internal ice then it should start to work again like new ..
same problem....ice not melting, meat frozen but ice soft etc...i cleaned it, clean vents and airways etc...no help...ruining food at this point! i need help
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
I don't see where a solution was typed.
