SOURCE: wires going to starter solinoid. 2 go into 1. is
They are connections but are special fuse links!, desighnd to burn out before your wireing O.K.?
Testimonial: "quick reply !! thanks"
SOURCE: I need the screws that hold the tube to the barrel
The question you have asked is not clear and specific, but let me try to help you. you can get screw to hold the tube for your barrel model 12 is easily availbe in any stores dealing with electroninc goods ,all you need to specify the model and brand name to the sales man If you are satisfied with my answer please vote three thumbs up.Thank you
SOURCE: 1986 dodge ram 225ci slant six and a single barrel holley carb
Start with the idle needle screw first, the idle mixture screw. Seat it all the way in, first-don't overtighten and damage it, just seat it lightly, and back out two full turns. Run the engine and set the adjustment by ear to get your best lean idle: start turning the screw in (clockwise) 1/8 or 1/4 turn at a time till engine stumbles, dies, or runs rough. Keep the engine running, and turn screw out (counterclockwise) a little at a time till you hear the idle dropping. Now between those two settings is your best lean idle. Turn the screw in, a little at a time and wait for engine to respond, tiill you get the highest idle speed. Now set the other idle screw, curb idle, to the idle setting for your truck, probably about 700 rpm. You can move back and forth between the screws to get the best steady idle. Just don't over do it on the idle mixture screw.
Good luck.
SOURCE: Need parts for winchester model 12 shotgun
The following website carries all the parts for the model 12
http://www.nulineguns.com/category_part_42_3_31_42.php
SOURCE: I bought an Iver Johnson single barrel 12 guage shot gun. Can anyone tell me about this gun?
It was built on the 1890 Hopkins and Allen patent and is very similar to several dozens of inexpensive single shot shotguns.
