Brother MFC 7840W Printer Logo
Posted on Oct 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i reset drum unit life counter on the mfc 7840w
Anonymous
Level 2:
Scholar:
  • Expert 107 Answers
  • Posted on Oct 08, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
107
Questions
0
Helped
44705
Points
382
Hello, i am going to ball park this, with machine on, open up front cover as if you are going to replace toner, press the clear button, on the display it may say, new drum press 1 for yes 2 for no, then close front cover. normally the drum comes with the instructions on this, but sometimes its missing, but also brothers web site has the info on this. i work on these alot so most of the resets are the same
  • 1 more comment
  • Brigid Golden Nov 03, 2010
    You are the BEST!!! Followed your easy directions and drum life counter has been reset. Thank you soooooo much!!!
  • ghghg281 Dec 19, 2010
    Amaizing!!! Sooooooo easy... ! thanks much!
  • Anonymous Oct 31, 2012
    Good Lord thank you so much!!!!!
1 Related Answer
Anonymous
  • 405 Answers
  • Posted on May 16, 2010
SOURCE: how do I reset the drum counter on the a Brother
open the front cover of machine ( where the cartridge is installed), then press the clear button, and then press 1 for yes for change drum question.
How to replace drum on 7840w printer
  • Open the door on the front of the printer.
  • remove the drum/toner from the opening pulling out and lifing up slightly.
  • remove the toner cartridge from the drum unit. (press green level to release.
  • insert toner cartridge into the new drum unit
link for general printer help : http://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=MFC7840W#.VNkfGfnF-RY
FAQ with instructions on drum replacement.
Frequently Asked Questions
tip
How to extend the life of a TN-330 drum kit for MFC-7840W Wireless Printer
If you have received any of the following messages on your Brother MFC-7840W wireless multifunction printer while utilizing the TN-330 drum kit then you may not have to replace your drum, at least not yet.
Drum End Soon
Drum Error
Toner Life End
Toner Low
I had this issue happen to me about 150 pages ago (some text, some pictures) and I still haven't replaced my drum after I executed this little trick.
Take your drum kit out of your printer (make sure you turn off and unplug any cables first)
Take some black electrical tape and cut a inch by inch square off.
Place the black tape over the optical port as shown in the picture below.
Then put the drum back into the printer, cable everything back up and turn the power on.
Your drum should last a long time beyond what was supposed to be a low toner.
Hopes this saves you some money.
29helpful
How to reset the drum on a Brother 7840
Remove old drum from the unit.
Remove toner and install in the new drum.
Place Drum Back in the machine, leave cover open.
With the cover door open Hold Clear/Back button (about 5 sec.) until the Lcd reads Replace/Reset Drum? yes? no?
Press 1 for yes and close cover.
The machine will cycle and restart, once it says ready the counter has been reset to 100%
7helpful
I have this model printer (brother mfc-7840W) and i'm getting an error on the screen-it says Drum Error. See troubelshooting and maintenance chapter in the user manual
If you have the manual follow the steps for trouble shooting.
It will tell you to remove the drum, remove toner, clean corona wire and reinstall. If that does not solve the issue it will recomend replacing the drum. You can check your drum life by going to menu- press machine info, choose option 3 drum life and press ok. This will show you the remaining percentage of your drum if the number shows less than 25% replace the unit.
If it shows more than 50% you can reset the drum counter allowing the machine to read it as a new unit.( Bare in mind this will change the usage meter back to 100%, you will have to keep an eye out for print defects or light pages as this will signal the end of the drum life) to reset page counter remove the drum from the machine, with the front door open press Clear/back until the lcd displays reset drum yes? no? press 1 for yes and reinstall drum. The machine will cycle until ready; if this still has not cleared the message you will need to contact brother for a manual reset or service.
68helpful
Drum error message
To reset MFC-7840W drum count use the following steps.
1. open the front cover (leave open).
2. Press clear/back.
3. Then confirm the new drum install by pressing 1.
4. The display will indicate accepted.
5. Then close the front cover.
This should be done each time the drum unit is replaced.
4helpful
I recently noticed a message that said "drum end soon" on the screen portion of my printer. With that I went and replaced the drum and toner. The problem is this: The "drum end soon" message never quit...
This message would continue to appear if the drum unit counter was not reset when you installed a new drum.
To reset the drum unit counter, follow the instructions below:
  • Press Menu on the Control Panel.
  • Press the Up or Down Arrow key to select Machine Info..
  • Press OK.
  • Press the Up or Down Arrow key to select Reset Menu.
  • Press OK.
  • Press the Up or Down Arrow key to select Drum.
  • Press OK.
  • Press 1 to reset the drum unit counter.
Thank you !!
29helpful
How do I reset the drum counter on the a Brother MFC-7840W???
35helpful
2answers
open the front cover of the machine then press clear back it will say replace drum? press ok
the quality will probably start getting pretty bad as you will be using the drum passed it's life
12helpful
Drum Error on Brother MFC 7840W
Has two situations:
  1. The corona wire on the drum unit needs to be cleaned.Clean the corona wire on the drum unit.
  2. The drum unit has reached the end of its life. Replace the drum unit.
136helpful
3answers
Reset the drum counter on Brother MFC-9840CDW
press the 3 and 9 button at the same time in ready mode.
then the reset menu will appear, press the up or down arrow until you get to drum.
press ok,
and select 1 to reset or 2 to exit.
it will return the ready state and your done.
Norman Weimar
Norman Weimar
k24674
