SOURCE: Printer Cartridges won't align C4180 printer
Printer keeps trying to perform an alignment after installing a new black ink cartridge fix:
1. Unplug USB
2. Turn printer off
3. Wait 10 seconds
4. Remove paper from paper tray so printer has no paper to print on
5. Turn printer on
6. Printer messages to insert paper in paper tray
7. Press and hold “Setup” and “ Cancel” buttons and press “OK”
8. Should be good until next black ink cartridge change.
SOURCE: I have a HP Deskjet F380 All-in-One. Error light keeps flashing.
Normal
0
Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off.
I'd do both and reinstall the CD software program that came with
the printer. When the software program asks you to connect the
printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
SOURCE: "black print cartridge is not compatible"
Ok the main mistake is cleaning the cartridge with alcohol because then the cartridge picks up dust and the dust sticks to it and then the printer will not work.
Now you can try cleaning the cartridges with a cotton swab dipped in water and see if that helps with anything you also gotta clean the contacts inside the printer where the cartridges are seated.
Make sure the printer is connected directly to the walljack without the surge protector and remove the cartridges,then power on the printer if you still face the issue, while the printer is on pull out the power cable from the back of the printer and the walljack wait for 30 seconds and then plug the cable to the wall and then to the printer and see if this resolves the issue,if you still get the error its a printer hardware problem.In that case also check the cartridge expiration date at the bottom of the cartridge if it shows out of warranty that could be another reason why you get this error message
SOURCE: HP PSC 2355 incorrect print cartridges error message
not quiet a solution dugguly but i've just had the same problem in reverse, i moved to the us with same printer, ink ran dry, it won't take hp94. after 3 phone calls and 4 emails with hp i learned that all hp printers sold after 2004 are regionalised, therefore a us printer will NOT WORK with UK bough cartridges and vice-a-versa. the only way round this is to call the HP support and ask to be taken through the step by step guide to reseting the region of your printer to the UK regional setting OR and this is my option, get friends/family in the US to ship US cartridges to you in the UK. Too bad as Tesco do a good line in gneric cartridges - Good luck - mattw
SOURCE: Print cartridge problem : [Tri- color]
Printer display says: Print cartridge problem : [Tri-Color]. Refer to device documentation to troubleshoot. I can find nothing in the 'device documentation' to help me.
