SOURCE: Video card installation
You will need to pay close attention to how many beeps & if their short or long. Asus uses the Award BIOS. Beeps are a part of POST. Power On Self Test. Open the link below to find out what your beeps mean.
http://www.bioscentral.com/beepcodes/awardbeep.htm
SOURCE: Laptop Screen White horizontal lines
Try reseating the LCD cable to the video card. If no change, then you will most likely need a replacement LCD (Roughly $150 on EBay)
SOURCE: HP Pavillion dv6700 - black screen
Do the following without the battery inserted.
Let the computer sit with no battery for 24 hours. Do not put the battery in at all. Try using your original memory stick ONLY, with no hard drive and see if it will POST. If it does, insert the hard drive and try again. Could be the new memory...
Another thing you can try is reseating the processor. Turn the ZIF screw, take the processor out (WATCH THE PINS!!) and put back in GENTLY. Leave the memory in the computer, hard drive removed, try to power on.
These models have been known for bad motherboards. Contact HP and arrange to send it in. If you do enough digging on HPs website, you'll find the service advisory.
-Dell & HP Certified Technician
SOURCE: I have an FS Amilo pi 1536 laptop, with a ATI
Start saving for a new laptop, that chequered effect is the sign of video corruption caused by a failed video chip. Replacing it is out of the question since a replacement part would cost more than the laptop is worth (unless you can find a sh one).
SOURCE: inspiron 15R(N5010) laptop
