Toshiba 40UX600U TV Logo
Posted on Oct 05, 2010
Two problems on my Toshiba 46UX600U 1. I have tried every possible way to connect it to my WiFi. PBC doesn't work in fact it crashes my TV forcing it to turn off and then on again. PIN also doesn't work as my Access Point says it successfully connected but no signal on my Toshiba TV 2. The more pressing problem is media sharing. I have many things on my home computer that I would like to stream on the built in Media Player but NOTHING plays back on the TV. Every song and video I have says Media Playback Error. For the life of me I cannot figure this one out. Oh and I do have the TV hard lined into my network since I cannot get the WiFi to work so that is not the problem with the question. Any help would be VERY appreciated! Thank you! -JB
spitzer
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 26, 2019
spitzer
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
855
Points
Not an answer: wireless access is continuously grayed out in menu even though adapter is plugged in. I reset TV to no avail. Wired connection works fine.
Anonymous
Level 1:
New Friend:
  • Posted on Nov 16, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
855
Points
I found that using the assisted setup i was able to connect wifi. try doing this. i also have qwest so i have the password. also make sure you have the wlan plugged in to the tv lol
  • e68154 Mar 24, 2011
    I just purchase the same tv and having this problem as well. I need help also.
    [email protected]
2answers
My Toshiba Satellite P55W-C5316 had a Toshiba update made it crash. It only showed black screen. How can I keep computer from automatically updating Toshiba update?
go to setting and turn off automatic updates, I think toshiba has a program for their updates I think its called catalyst disable the updates there too
https://www.6ya.com/mr.mike good luck
Lg smart tv model 42LS5700 can I connect to WiFi if so how?
These extracts from the user guide should solve your problem:
To connect network through Set Expert
HOME ? Settings ? NETWORK ? Network Connection
Used in special circumstances such as in offices (For example, when a static IP is needed).
1 Select a network connection either through Wired or Wireless.
2 When connecting via Wi-Fi, use the one of the following network connection methods.
AP List Connects the network by selecting a network from the AP
(Access Point) List.
Enter the SSID Connects by typing in the name of wireless AP.
WPS-PBC Connects easily by pressing the button of the wireless AP supporting PBC.
WPS-PIN Connects easily by typing in the PIN on the web site of the desired wireless AP.
Ad-hoc Connects directly to via a wireless-enabled PC or mobile
phone.
For the full manual follow this link:
http://www.lg.com/us/support-product/lg-42LS5700
My Toshiba L505 ES5018 FN keys is not working
Hello. It's possible the driver for the wireless card(network interface controller) was not installed properly. Try to download the drivers from Toshiba website and install on your laptop. You may get the WiFi Driver from this link
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2520800&rpn=PSLU0U&modelFilter=L505-ES5018&selCategory=2756709&selFamily=1073768663
There's two WiFi Driver available, try to use the Realtek first and if it doesn't work try the Atheros. If WiFi driver installed correctly you should no longer see the "!" symbol and you will be able to enable wireless on your laptop using FN key combination.
Hope this works for you.
What's your problem?my ipod is asking for password to connect to wi-fi, what is my password? How do I find out what my password is?
Go to the Belkin setup page (http://192.168.2.1/index.asp) and select Wireless 1) Wi-Fi Protected Setup(WPS)
Select
2) Push Button Configuration (PBC) Method Push and hold PBC button on your Router for 3 seconds or click "Start PBC". Then start PBC on the device you want to connect to the Router within 2 minutes.
2answers
Cant find the wifi switch
Press the Fn + F8 on the keyboard.
The Fn key is located at the bottom right corner of the keyboard and F8 (you'll see a small antena icon with F8) is at the top center.
(See Fig1)
Fig 1 - Keyboard Layout
Regards,
Shrey
Had the unit (46UX600U) for about 8 months with no problems. In the last couple of days the unit will seem to turn itself off and then back on. The green light never goes off though. This happened once...
If going through a cable box you may be loosing signal from time to time. Try playing a DVD to rule out the possibility that its your tv. Try replacing cable box, or add a cable amplifier. Hope this helps.
Brand new Toshiba 46ux600u . Power on and pressed menu to start but nothing happens.
this is a LED 46 " TV , not computer ! please send your issue to the correct category
I can't connect to a wireless internet. I think it's a problem with the driver. The model is a663, Toshiba Satellite. I've download a wi fi driver and intalled it, it worked for a few minutes and then the...
It could be caused by conflicting software, if you have your device software and windows software trying to setup wifi connections.
Check on the task bar for two icons and right click on one of the icons and select disable.
My wifi device actually works better using windows to configure wifi so give them both a try.
If this is not the problem try renewing IP address,
Click Start on task bar,
click the Run... icon
type cmd in the box and click ok
in the cmd box type ipconfig /release
then ipconfig /renew
5helpful
4answers
I have a Toshiba Satellite L500 and the wifi won't work. Have read other forums and apparently it's a faulty wifi card problem. How can I get this fixed without shipping it around the world. I'm in the...
  • Hi, I hope that you are still monitoring this "Website" for a "Solution?" I might be able to help you. Follow these instructions, and we will be able to get you connected. I'm familar with the "Computer Model" that you have, so lets get started! First, click on the (Start button) to open the "Start Menu," next "Type" in the (Search box): "Toshiba." In the Program list; find the Toshiba Application Installer, and "select" to open. The Driver Installer "appear." Now you can select, and install the Wireless Drivers; click on the "Next" button, in the ("choose an item...") window, select the By Name: Wireless LAN Driver, and to the (right), click on the "Install" button. To finish click on the "Exit" button. Note: Follow all instructions thereafter exactly. "I hope this help you, let me know, if possible"
M300 toshiba connecting to locally, not connect to internet
Dear Shifsa,
Considering the fact that you are trying to connect to a wifi connection which of course is unsecured,
here are some workarounds..
1. Uninstall the wireless card driver.
Go to device manager > click on the + sign beside network adapters > right click on the wireless adapter and select uninstall. Restart the computer it should get reinstalled automatically.
2. try disabling or uninstalling the antivirus or internet security software. you can later on again download the a free software from www.hippo.com
Hope this helps.
Regards,
Anup
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
