Emergency emptying hose pulled out too far and come away completely, now machine is leaking. How do I reaffix the hose. Can I take the panel off the bottom around the prump,
SOURCE: Problem C2 with AEG Lavamat 86741
Find the drain pump (on most front loaders, it's at the bottom of the machine at the front - often with an access hatch).
Open it up (you may want to tip the machine backwards and put a basin underneath to catch the water - and be prepared to close up again if the basin gets full before the machine is fully drained). Check that the pump impeller isn't jammed with a collection of old coins.
My next move would usually be to set the machine going in a part of the cycle where the drain pump is supposed to be running, and to give the impeller a quick flip with my fingertips (taking great care to avoid injury). If the pump doesn't run until you flick it, but then starts, this is a sure sign that you need to replace the pump motor - a quick, cheap and easy fix.
If the pump starts by itself, the the problem is more likely to be one of blocked hoses.
If the pump won't start at all, either by itself or when you flick the impeller, you need to check whether the pump is getting electricity. Do this by disconnecting the machine from the mains, connecting a voltmeter across the two terminals on the pump, then switching back on and selecting a bit of the cycle where the pump is meant to run. If you see mains voltage, then again you want to change the pump motor. If you don't, then check all the associated wiring before starting to look at the main timer. Disconnect the power before removing the voltmeter connections.
A.
SOURCE: need the manual for Aeg oko lavamat 74630
Dear Biyo,
Please download the manual from here. (simply press left click)
http://www.manualshark.org/manualshark/files/5/pdf_10516.pdf
I have sent you an email as well.
Regards,
EngineerGR
SOURCE: Lavamat 16820
The reason the machine is coming up with E20 when drying.
is that there is a blockage of fluff in the dryer air duct on the right hand side of the machine just below the fan unit.
the air that goes through this duct is heated and returns back to the tub to dry the clothes. because there is a blockage in this duct the fan pushes air up the pressure switch tubes and fools the machine in to thinking that there is too much water in the drum,
too remove this blockage you have to disconnect the power supply, remove the lid and remove the back panel, 4 screws at the bottom + 4 up top under the lid.
plull the water pipe with the valve out of the way and pull back panel away.
you should now see the dryer condensor unit blocked up with fluff. remove this unit and clean with bottle brush.
replace and make sure hoses are done up tight. replace back panel and lid, try again on drying and things should be alot better, drying should be alot quicker as well.
SOURCE: AEG OKO-Lavamat 1271 VI Turbo
Sounds like the main drum bearings have failed.
At this age , I don't think this is an economical repair to undertake.
Better to replace with a new one.
SOURCE: AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
hi - i just wondered if you found a solution to this, as i think i've just done exactly the same thing!
me too!
