Dear If the printer stops after exiting a small portion of the print paper then the problem is from exit sensor. Exit optic sensor needs to be replaced with new one. Kindly coordinate with authorised service center to get it fixed
SOURCE: Samsung CLP-315 prints half a page and then stops
It sounds like your fuser is causing the jame,.
when you remove the paper can you wipe the toner off the page or does it adhear to the paper ?
If it does not the fuser is causing the jam, if the toner does not wipe off the paper then the feed tires would be the cause of your jam
The fuser is at the back of the printer and will be very hot, so be careful.
SOURCE: Samsung CLP-315W Color Laser Printer will print only half page
http://www.fixya.com/support/t3934542-exit_sensor_problem_samsung_clp_315
SOURCE: Printer stops printing half way through as page ge...
your printer exit sensor has mulfunction. it got be replace.
SOURCE: samsung clp-315 printer stops printing after half page
i have samsung colour printer. half page printing then stop the printer. after turn on the printer the balance page automatic take out
SOURCE: My Samsung CLP 315w refuses to print a whole A4
Hi, My problem is exactly the same as karenpankhur's on Apr 16, 2010. Samsung CLP 315 refuses to print a whole page. Stops 1/2 way then message, paper jam, open front/back & close, paper not jammed & when it's closed document continues printing then prints another one of same, stopping 1/2 way. Thanks, Monte
