Texas Instruments TI-83 Plus Calculator Logo
Posted on May 17, 2008
Parts of the calc never turns on in the screen..
Whenever I turn on my TI-83 there are some parts in the screen that wont turn on. For example, if I put in 4+4, the answer comes out in the right side as 4. But there is a vertical line that blanks out that line. So the middle of the 4 is missing and there is a horizontal line so I can't even tell what that number is. Can someone help me?
  • 1 more comment
  • jkcarter May 27, 2008
    I've had the same problem with both my old TI-85 and TI-89. Could someone please help with this? Is there a way to fix it?
  • lucee25 Nov 30, 2008
    Several vertical lines of pixels never turn on for me. Sometimes, when I keep the screen on for an extended period of time, some of the lines come back, but this is not an adequate solution.
  • ria ria Dec 02, 2008
    there are vertical lines that show up on mine and when you clear the screen some go away and new ones appear. what happened to my calculator? and can i fix it?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 20, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
742
Points
What are the parts of the calc screen?
How to solve trig functions using ti-83 plus
Your best bet would be trying a math package on ti-calc.org - you can usually find something that does what you want there. You'll need a cable and the software to download these programs to your calculator. Here's a link to the trig section:
TI 83 84 Plus BASIC Math Programs Trigonometry ticalc org
6answers
Equations
You can't simply enter 7x+9=30 into the calculator, there is a way to calculate what the x is but its been a few years since I've done these..
My ti-89 screen is frozen and wont accept input
Remove the batteries and wait a minute or two. Put them back in and turn the calc back on and it should function normally. Check for stuck buttons as well, as sometimes they will cause the calc to appear "frozen".
2helpful
I turn on my calc and the hole screen is black. i can see anything at all, i know that it on but nothing but black
Turn the calculator on. Press and release the 2ND key. Press and hold the Down-arrow key for a few seconds until the screen lightens.
2helpful
Entire battery replace but still wont turn on
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
Ti-83 plus silver edition. calc won't turn on.
Well, if screen shows the RAM CLEARED message, that means your calculator is working. Just press the [CLEAR] key, message will be erased and you are ready to crunch numbers.
Hope it helps.
Black lines on the screen of my ti-83 plus
try to change the contrast of the your calculator.
28helpful
TI 83 Plus won't turn on after battery change
I was having the same problem...I found the info below on another blog and it helped me fix my calculator problem. Take out all the batteries, hold the DEL button and put the batteries back in (keep holding the DEL button until all batteries are put back in). This will restart the calculator and restore it to its default settings...but it makes it work again!
"Reflashing the OS is probably the thing to do now. I think there's some trick that throws the calc into OS receiving mode. Hold down DEL while putting the batteries in? I don't remember if that's it. Go to 1-800-TI-CARES/[email protected] if you need specifics on getting the calc to take an OS upload given the state it's in."
2helpful
TI-83 Plus Silver Edition 1.14
That means that you know your calc crashed. This can be caused by taking out the batteries durring running time, happened just randomly. Well nothing to fear just press clear and it should go away but if it stays on that screen you have problems and is best to try some of these methods. Take out all the bateries and press and hold the on button for 30 seconds. Put the batteries back in and it should have reset. Warning you should archive everything incase this happens. To archive go to 2nd mem and hit enter to put a astrick next to the app (meaning archived)
2answers
My ti-83 plus has OS problem
That happened to me a few years ago - my friend tried to give me his operating system, and my calculator was all locked up like that for a while. There's some kind of reset code - pressing some buttons while putting a battery in - but it's been a while, so I don't remember which buttons.
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
