Region codes are copyrighted so we have no way to supply them.
Please give the model number of LG player model #
Thank You
In most models the unit cannot converted to multi-regions.So it will play only in the specified region in which it is applicable to.But in some unit models there is a procedure to turn the unit to multi region so it can play all region dvd.On all models the procedure to convert the unit to multi region is different.As you have not mentioned the exact model number of your unit.t will not be easy to give exact details.If in case there is a procedure to convert your unit to multi region.
Thanks. keep updated for any more query.you can rate this solution
and show your appreciation.
No there is no code actually provided by LG for LG HB965TXW home theater system:----
The LG service center reply for this code to other expoerts are:---
Thank you for emailing LG Electronics Australia.
"""""LG do not manufacture 'multi region' or 'Region free' DVD players, nor are we able to supply a code to change this.
Australia is coded as region 4 and as such all LG players made for the Australian market will play Region 4 discs only. """".
This is what LG has to say.
But few others who had this same problem Got helped with this procedure.But its not 100% guaranteed .In some cases it helps and in some cases it dont.But still you can try.
1. Open DVD Drawer
2. Pressing "0000" on the remote.
3. A screen appears saying NEW REGION CODE and displays the current one.
4. Press "0" for all zones.
5. Press the "select" button on the remote.
6. Close the CD Drawer.
7. Power off.
Thanks for keeping updated with your query.
Hello, here is the way to tell which Region Your Particular System was Permanently set for: Regional Codes This unit has a regional code printed on the rear of the unit. This unit can play only DVD discs labeled same as the rear of the unit or "ALL". • Most DVD discs have a globe with one or more numbers in it clearly visible on the cover. This number must match your unit's regional code or the disc cannot play. • If you try to play a DVD with a different regional code from your player, the
message "Check Regional Code" appears on the TV screen.
So, basically if Region Code that is Printed on the back of the Unit is any othe Region besides "ALL: or "REGION 1", you will have to buy a different System thats set to Region1 OR buy DVD's that are compatible with your system..
Please Rate my Suggestion if you would. It will activate my Stats for your issue. Thank You
It is a HB965TXW home theater
The unit is a LG HB965TXW home theater system
Nothing! no screen with regional code just blank. Thanks for trying though
HB965TXW
Unlocking a LG HB965TXW regional code
surely you can unlock the unit to play any region. These DVDs play on all my other cheap units
Sorry I don't know anything about rating you?
But it can be unlocked?
Hey Supernova...how do we rate you?
Hi. Yes I knew that, but is it possible to unlock this model so that I can play other region DVDs on it?
