Does anyone have code to unlock an LG LH-W750 dvd player?
The number of pressing "0" ( two or for ... times ) change about model...
so check the TV screen while you press "0" for see the region setup menu ...
Press [POWER]
Wait for "no disc" to apper
Press [OPEN/CLOSE]
Press [0] four times
'Region Edit' & 'Region Code' appears on screen
Input [0] in Region Code for region free
press [enter]
Press [Pause/Stop]
Press [Power]
SOURCE: DVD PLAYER MULTI REGION CODES
you can change your dvd region code but i advise you not to change it instead use a software . here is the link for the software to download :- http://www.4shared.com/file/19492658/43612f11/DVD_Ghost.html?s=1
if it doesn't work then contact me ok.
Your LG LH-W750 is a 700W Wireless Home Theatre and the DVD player is only one component of the system. Having said that, the DVD player would not be carrying the same model number. It would be the mechanism and circuitry of another model and incorporated into your main unit. Hence region free code would have to be for the original model number of the DVD player and not the Home Theater. Sorry.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
