SOURCE: TI 84 Plus...Screen Black, but I can see the shadows of the background.
make sure you hit the 2nd button before hitting the contrast button. you need to hit the 2nd button everytime you hit the contrast up button
SOURCE: None of the buttons on my TI-84 Plus calculator are working.
is the cursor the graphing cursor or the normal typing cursor?
SOURCE: ti-84 plus silver edition
press 2nd and then the down arrow over and over until the contrast is adjusted. Did you read the manual?
SOURCE: how do i use the inverse log operation on the TI-84
If I understand you correctly, the inverse of the log operation is exponentiation. So if your log = x, the inverse is 10 raised to the x power. On most TI calculators this is on the same key as the log function.
michael
SOURCE: my TI-84 plus won't turn on... even with new batteries
Could be the screen has been dimmed so much that you can't tell that it's coming on. Press on and then 2nd button and the up arrow key. You may need to keep pressing 2nd and up arrow key. This is how you darken the screen. You can also lighten the screen which may be the problem you have by pressing 2nd and then the down arrow key. This is how the contrast is controlled on your calculator
If this doesn't work, take out the internal battery that is located in a tiny door with a screw right above the 4 AAA batteries. Leave this out for about 8 hours and put it back in. Put in the AAA batteries and the calculator will be reset and may work.
If you want to examine the matrix you want to inverse and, the one that is given you trouble pressing [2nd] [MATRX]. Then stroll and, select the one you want to look at by pressing, [ENTER]. You'll have to press, [ENTER] again and, matrix should display at the Home screen. At the Home when you get to them your looking for the ones that are not square, like 2 by2 or 4 by 4 etc. You might need to re-edit this matrix so, that it is square.
Your trying to invert a matrix that isn't square you might be using using the proper key sequence to create a inverse matrix. Here what the correct inverse matrix look on the Ti 84 Plus Home screen.
And pictured below is a Matrix is being inverted by using the ^ and the -1 keys. Which to inverse a Matrix on the Ti 84 Plus you have to use the [x^-1] key.
This is not the proper way to inverse a Matrix on the Ti 84 Plus. The proper way to inverse of a matrix, the [x-1] key must be used, instead of pressing the sequence [^][-][1]. The [x-1] key is the official inverse key and is located right under the Math key. It is also the same key that you use to get to the matrix menus. The [^][-][1] sequence is only raising the matrix to the -1 power and, will cause an error too. If you need any more help, just post a comment and, I'll respond quickly.
