Polaroid i531 Digital Camera Logo
Posted on May 15, 2008
My lens won't retract or open and beeps 3 times and shuts off
I have a samsung digimax my lens won't open or retract and it just beeps 3 times and shuts off
  • 7 more comments
  • Anonymous May 23, 2008
    my lens won't retract or open and beeps 3 times and shuts off problem
  • Anonymous Jun 02, 2008
  • Bratz99 Aug 09, 2008
    Its something wrong with it when i cut it on the screen was white and all this colorful stuff on there.And then the lens wont go down when i turn it off then t beeps 3 times water didn't get on it or nothing.
  • Anonymous Oct 02, 2008
    these cameras ****!
    mine just shut off, with the lens out, and when i tried the power button, the green light would blink and it would beep 3 times.
  • Anonymous Dec 31, 2008
    beeps 3 time s wont work
  • Anonymous Mar 17, 2009
    how do you "inspect the lens from all angles" and "press in the opposite direction of the abnormal lens direction" ?
  • staceyo_2009 Mar 22, 2009
    my camera beeps 3 times and shuts off even when i use new batteies it wont tun on.
  • Anonymous May 11, 2010
    beeps three times lens wont retract in or out and camera shuts off
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 31, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
385
Points
THE ONLY SOLUTION I HAVE IS DO NOT USE THE ABOVE SOLUTION:
  1. Using gentle finger pressure, press in the opposite direction of the abnormal lens direction
  2. I heard a snap, then I powered the camera on.
I did just this and heard a snap alright! My lens is now completely broken! I am not a strong person, so it doesn't take much to break the lens! My camera is better off in the trash now!
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jun 28, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
Helped
2212
Points
12
I had a Polaroid i531 that would beep 3 times then shut down & the lens wouldn't retract.
I fixed it like this:
  1. Inspect the lens from all angles and you'll see that the lens assembly is out of sync. (My was looking upward ever so slightly)
  2. Using gentle finger pressure, press in the opposite direction of the abnormal lens direction
  3. I heard a snap, then I powered the camera on.
  4. Camera now works.
Samsung digimax d53 beeps then shuts off with lens stuck out
The camera lens is jammed, caused by dirt or worn out gears. a camera technician would be solution but not cheap, or you can take matters in your own hands and try a risky trick "NOT RECOMMENDED" take the palm of your hand and sharply hit it around the lens housing and applying power as you do so in an effort to get lens to retract, if you are lucky it will work or make things worse.
1helpful
Lens not extending
You have a lens problem. Sure it can be fixed but be sure to get an estimate first.
4helpful
My samsung l830 camera lens is stuck open and when i press the power button it beeps 3 times and remains blue then does nothing
If the lens on the camera is stuck out, look to see if it's a little crooked. If it is, try to gently straighten it. If it still won't retract, try to gently push it in as you turn the power on.
If it won't turn on (the green light blinks and it beeps 3 times) push and hold the 'power' button and the 'play' button at the same time for a few seconds - it worked for my S730. Good luck!
8helpful
I turn camera on. Lens comes out. beep 3 times. turns off.
Everytime I try to turn it on, the lens comes out for about a second, the camera beeps 3 times, the lens retracts and the camera shuts off. The battery is completely charged and the camera is only 4 months old. HELPP :(
4helpful
3answers
Camera Stuck with lens out. Beeps
I dropped the camera on the table a couple of times, twisted the front of it. Suddenly the lens retracted into the camera, the beeping quit, and now I can take pictures again. The Samsung website is horrible.
1helpful
Camera beeps loud 3 times and shuts right off!!
sounds like a lens error, does the lens extend or retract? You probably have to get the lens back on track, use gentle pressure wiht the camera face down on a towel covered table and turn on to see if the camera tries to retract the lens. I really dislike these types of cameras that extend the lens everytime, if it turns on in your pocket, your doomed!
1helpful
5answers
Digimax samsung s500 beeps 3 times lens stuck wont stay on
Mine got stuck with lens out. The batteries were new so I never imagined it could be the batteries, but they were cheap ones so I recharged a pair of good ones and once I put tried them on it worked just fine again. Conclusion, the "new" cheap batteries had only enough energy to turn it on and then they couldn't give it enough energy to make it work anymore and that's why I couldn't retract the lens or even turn it off properly. So in your case, try using a couple of good and new batteries.
Digimax 430 camera won't turn on
If your lens is open and the camera turns off after those dreaded beeps, I have a fix for your problem. Basically, for this model of camera, the lens first pushes out a bit and then it retracts into the camera. Well, my lens got stuck on the pushout and it prevented the camera from turning on. I used some finger pressure and wiggled the lens a bit. Then I turned it on and it retracted to where is was supposed to be to take pictures. Then I turned it off and it retracted into the camera. Problem solved!
1helpful
6answers
It dont turn on
I had the same problem. Try to turn it on, 3 beeps and then it would shut down. Screen would come on for that time. Also, the lens was stuck open. It wouldn't close.
I twisted the lens (gently) and it appeared stuck. A gentle screw motioned seemed to free it. I hit the power button and it come on, but this time no 3 beeps and shut down. I then turned it off and this time the lens retracted and closed.
So, it appears that if the lens gets stuck open, it has a shut down feature that doesn't allow the camera to go further into its operation modes. I believe this stuck open problem occured on our camera when the batteries went low.
Again, a second of gentle twisting seemed to unstick it and with fresh batteries in, it was able to operate and shut down properly.
As far as batteries, I use the rechargeable Ni-Cad 2500 mA. They last a while.
Blessings to you!
I am have Samsung Digimax S600
Well all the time these item [didgi cams and small electronics of all sort do seem to have a high fail rate. But as I said less than a year - take it back
Top Polaroid Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Tom Shanks
Tom Shanks
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
