Home Security Logo
Posted on Sep 11, 2010
I purchased a new Sentry Safe, Model CSW 4747 yesterday. When I unboxed the safe, the safe was open, the lock handle was down, cyclinders were a little pertruding, and the lock cyclinder was popped out. I installed battteries in the electronic lock as directed. I AM UNABLE TO GET THE SAFE TO LOCK. THE LOCK HANDLE WILL NOT MOVE UP OR DOWN. I AM NOT GETTING ANY "LOCK" OR "UNLOCK" ICONS ON THE KEY PAD DISPLAY. WHEN I ENTER THE FACTORY COMBINATION, I GET AN ERROR CODE. Is the safe damaged OR defective? Am I in user error? How can get the safe to operate correctly? Should I take the safe back to Cosco and get another one?
  • Michael Pabaira
    Michael Pabaira Mar 15, 2019
    Hello mam /sir it possible if you give the passcode of your csw4747? Bec my auntie she forget the manuel. So the csw4747 not yet open. Maybe its same passcode in manual. Thank you
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 13, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2153
Points
9
(1) sounds like the interior lock activation screw is still installed. it's the long screw on the inside of the door with the yellow tag; (2) when entering the code, make sure the key is turned to the right; (3) after entering the code, make sure you next press the program button. enter the code wrong three times and it locks up for two minutes.
How to open Sentry safe ms3817?
There are several possible reasons why your Sentry Safe MS3817 is not responding to the handle or new batteries. Here are some steps you can try to fix the problem:
  1. Check the batteries: Make sure the batteries are properly installed and not depleted. You may also want to try using a different set of batteries to see if the issue is with the batteries themselves.
  2. Check the battery contacts: Make sure the battery contacts are clean and free of any debris. You can clean the contacts with a soft cloth or toothbrush.
  3. Check the handle: Make sure the handle is not damaged or stuck. You may need to apply some lubricant to the handle to loosen it.
  4. Check the lock mechanism: Make sure the lock mechanism is not damaged or stuck. You may need to apply some lubricant to the lock mechanism to loosen it.
If none of these steps help, you may need to have the safe serviced by a professional. As for the factory code, it is recommended to contact Sentry Safe or the retailer where you purchased the safe for assistance. They may be able to provide you with the factory code or help you reset the safe.
Have key and code...safe will not open
Sentry Safe not unlocking - YouTube
? 0:36
https://www.youtube.com/watch?v=4mbtSUAoS6w
May 8, 2013 - Uploaded by 1diazsantana1
When i put the pass-code on my Sentry Safe the handle will remain locked and I ... mine dont want to open either! i get 5 beeps ... How To: Open A Locked Sentry Safe If You ForgotCombination Code Or Lossed Key Model Is ...
Opening a Sentry Safe with a Rubber Mallet, some WD-40 ...
idoneitmyself.com/.../opening-a-sentry-safe-with-a-rubber-mallet-some-...
May 7, 2010 - Since this safe can only be opened with an electronic code, this is a .....i have sentry V260 electronic with key, no handle. cant find key and ...
Have had a CSW 3813 Sentry Safe for several years. Have had no problems until lately. Key #2090 opens the lock, we punch in combination that we have always used, then punch enter. The response is, the...
Sounds like you need a new battery replacement.
To replace the battery pack, unscrew the screw below the electronic lock case, turn the lock case to the right then remove it.
You can have the online manual from the link below, just make sure you have installed the adobe acrobat reader on your computer to view this file cause its pdf format.
http://www.sentrysafe.com/pdfs/OwnersManuals/503662.pdf
Additional info can be found from this electronic safe sentry manual
http://www.sentrysafe.com/pdfs/OwnersManuals/505748.pdf
If the problem leads to acquiring the right combination for your safe.... call the attention of Sentry Safe Shop
You must call (800) 828-1438 for combination retrievals.
or send a notarized letter stating you are the owner of the safe, personal information, model and serial number of your safe and must indicate the method on how you will receive the combination.
See further details from this link
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Please post back for any clarifications and let me know so I can help you further.
2helpful
2answers
I WANT TO CHANGE COMBINATION ON MY SENTRY FIREPROOF SAFE HOW?
I have a sentry safe csw 4747 Idont no tha combination
how do I do the safe a key and electronic key pad
How do I open the combination lock to my sentry home safe?
Locksmiths advise these Opening instructions for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open.
sentry safes opening instructions for 4 # combo locks
Turn the dial to zero.
Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the third time).
Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
Turn the dial to the right to the last number (stop the first time on your last number).
Pull the handle down to crack the sentry safe open.
Lost keys to SFS Security Chest 1100, need S/N or option to open
You can go to www.SentrySafeShop.com and do a search for keys. You will then be able to enter your information as listed below and they will send out a new set to you. Much cheaper than having to destroy a perfectly good safe to get into it.
For Small Chests or Files: (Model numbers will begin with 1100, 1160, 2100, etc... ): A lock reference number is required. It will be a letter, a number, a letter and number, or "blank" (no letter or number), engraved/located on the silver cylinder of the lock (right around the hole where the key goes in at).
For Personal, Home and Home/Office Safes: (Model numbers will begin with: S0, S3, S4, S5; I0, I3, I4, I5; A3, A4, A5; J3, J4, J5; L0, L3, ,CS,CSW,DA,DS,KS,KSW,MS,MSW,OA,OS,and SC): Indicate your model number and the safe serial number found on the front right-hand side of the door, between the hinges.
2answers
Lost key
We cannot legally provide any information about safe opening. We have no way of checking to see if you are a burglar. Contact a safe company in your area or ring SENTRY and they will check the REGISTERED Owners details and then send someone to either open it or arrest you.
Thanks for using FIXYA
3helpful
CAN NOT OPEN MY SAFE, MISPLACED INFO, LOCKED CODE NUMBER IN SAFE. ELECTRONIC FIRE SAFE NUMBERS ON OUTSIDE OF SAFE OA3817 BA69609
To retrieve your lost sentry fireproof safe combination. First, find your safe's Model and Serial Number. The Serial Number is printed on the small label on the right side of safe (on paper tag near hinge) or under handle. As this information is confidential a valid credit card and email is needed to verify a customers name and address
sentry safe combination archives searches. Do come with a service charge although it's definitely cheaper then buying a new home electronic sentry fireproof safe.
A
good locksmith should be able to help you with the dialing programming instructions and lost Sentry Safe Key Replacements
Top Home Security Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Home Security Expert? Answer questions, earn points and help others
