120v present at outlet....almost all lights are on with the display but control panel does not respond or reset. no fault codes....i have a good multimeter and some troubleshooting background, there was a small packet in the unit that described check out procedure for speed control and motor but nothing for control panel.?? Voltages were real low from speed control so I changed it....unfortunately for me that does not seem to be the problem. Please help if possible. Thanks
SOURCE: Kenmore front Loader 41729042990
remove motor, check carbon brushs,replace if short,the manual may help.motors that have brushs are the principle,sole motor is Italian,yours is German,anyway thats beside the point ,its the brushs.buy ,eire
SOURCE: unlock the control panel to a kenmore elite front loader
to unlock the controls
select and hold drain/spin for 3 seconds until the control locked status lights turn off.
SOURCE: kenmore eliete washer fails to do anything
probably bad main control under top left rear ..ck for bad connections first just in case
SOURCE: my front load kenmore 417-44072300 wont agitate or spin
you have a belt broken, drain out the water and take the back of machine off and you will find the belt then go to a place that sellls appliance parts andget a new one
SOURCE: Kenmore Elite HE3 front loader F-11 and FDL codes
yes!! the F/11 is triggered under high voltage conditions like high speed spinning. The part is called the MCU motor control unit. if it goes into failure while using your machine and locks the door, just wait 3 minutes and the door will unlock after the MCU resets. Try using you machine with a low speed spin for awhile.
i have a frontloader 3.5 capacity. we washed a load yesterday but then all my panel lights were on and would not allow me to reset. i unplugged and tried to reset it that way many times with no luck. my door light is not locking and i can open and close it as i please but it will not reset. i have tried the breaker switches as well with no luck. there is no laundry in there and it ran the full cycle last wash. has anyone else had this problem and been able to fix it?
