SOURCE: I need installation guide for autopage rs-855 car alarm
I've uploaded the installation manual and wiring diagram to Yousendit.com. Here's the link:
https://www.yousendit.com/download/dVlvdFdVdVVrUmxMWEE9PQ
or
http://tinyurl.com/dhs964
SOURCE: where is the relay system on a car alarm
it is a standard bosch style relay, it should be under the dash on left or right of the steering cloumn
SOURCE: i have the normal alarm Autopage AutoPage C3RS603
Nothing is hard to hookup just time consuming andf it all depends on how good you R with wiring how good R you..?
SOURCE: I HAVE A 2011 TOYOTA
Did you get both starter wires hooked up? That is usually the problem. Also make sure your transponder light in the dash is NOT flashing upon remote start.
SOURCE: The autopage starts just fine but when you put the
you installer wired the 2nd starter wire wrong. You need to have a double starter disable installed. This is a common procedure for your vehicle.
