Whirlpool RF378 Electric Kitchen Range Logo
Posted on May 11, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
F5E1 error my oven started beeping and showing the error F5E1, i didn't try to use the self clean ............. please help
  • 3 more comments
  • gromo2082 Oct 08, 2008
    I used the self cleaning feature on my Whirpool oven and now it won't unlock. How can I get it open?
    Adam
  • jenniesue57 Dec 08, 2008
    my lock wont open after i self cleaned
  • rede1947 Dec 12, 2008
    After self-cleaning, E1 F5 shows and the door will not unlock on my Kenmore 665.95179300
  • denisenelson Feb 27, 2009
    Out of the blue my oven beeped and the E1 F5 came up on the display followed by the E0 F3. The fan turned on and would not shut off. I finally turned the circuit breaker off to stop it. What is this all about?
  • zorgen Mar 22, 2009
    Everyone talks about the problem. What is the answer!! Please!
Anonymous
Level 2:
  • Expert 117 Answers
  • Posted on May 11, 2008
Anonymous
Expert
Level 2:
Answers
117
Questions
Helped
66828
Points
275
Whirlpool-KitchenAid-Roper Appliances: Oven Fault Codes:
>>Exception Note:<<
Chart below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
F0-E0 Analog to Digital failure
Disconnect panel for 30 seconds
Should the above error re-appear, replacement of the control is required.
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
  • Anonymous May 11, 2008
    That sounds like you have problem with the door latch
    Try to get a repair man to fix
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 14, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
22567
Points
I had FSE1 as my error. Door would not lock. I tried it again, this time PRESSING ******* the door where the lock is. IT LOCKED! WHOOT!
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Aug 31, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
26504
Points
15
  • Anonymous Aug 31, 2010
    hope it helps
3 Related Answers
Anonymous
  • Posted on May 01, 2009
SOURCE: tried to selfclean my NEW oven but get error message F5E1
Reading all the questions and responses - I had the same problem (would press "self clean", it would run for less then a minute then give the error message), so once I saw the code was E5F1 and what it meant (thanks for whoever posted that), I just pressed on the door for the first minute of the cycle, and self-cleaning then worked. Go figure :)
Anonymous
  • 112 Answers
  • Posted on Jan 23, 2008
SOURCE: self cleaning electric range oven...lost instructions...need to ASAP
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=GR399LXHS&siteCd=WHRCOM
heres a link to your owners manual
Hope this helps!!
Anonymous
  • 87 Answers
  • Posted on Feb 15, 2009
SOURCE: Self Cleaning Oven beeping and reading FSEO
Go in the back of the oven and there should be a tech sheet in a plastic bag. It will tell you what that code means. I assume it's a problem with the lock and switch mechanism. See what the code says it is
How do I find out what FSE1 or F5E1 means on my oven display
If your oven is by Whirlpool (or from that family), the F5E1 error code indicates that the door lock mechanism is damaged, lock motor isn't working or the sensor can't tell if the door is locked. Did you try to do a self-cleaning cycle on the oven recently? Can you open the oven door? Look at the lock mechanism near the top of the door jamb in the oven and check whether the latch move freely from left to right and back. If the oven door is locked, you open the back panel and try to manually move the lock mechanism to open the door.
Please add a comment with the model of the oven for further assistance. The model number will be on a plaque on the oven frame for most models.
I hope this helps.
What is the solution if my oven beeps?
Hello friend, thank you for your inquiry!
I understand that your door is locked and you have error "F5E1" showing on your range. I would perform a reset on your appliance which can be done by flipping the household circuit breaker off for roughly ten minutes. If that does not correct the issue and you continue to receive the error "F5E1" I would contact a professional to come out and repair your appliance because it could be an issue within your UIB (user interface board) or main control panel. Hopefully this helps. -Matt
4helpful
I HAVE A WHIRLPOOL MODEL NUMBER RF368LXKQ RANGE AND WHEN I TRY THE SELF CLEAN BUTTON I GET F5E1 WHAT IS THE PROBLEM
The F5E1 error codes means that the door light switch OR a switch on the self clean latch has failed. If the oven light comes on and goes off when the door is opened and closed it most likely going to be a switch on the latch thats the problem.
The part numbers are;
DOOR LATCH W10107830
LIGHT SWITCH 3195993
GENE
2answers
I used the self clean cycle and it has cooled off now getting error F5E1 and won't unlock? Please help. I use my oven almost daily!!
F5-E1 is a door lock error. Depending on the extent of the error, a hard reset may recycle the door lock and allow you to use the oven. Turn off power to the oven for 2 to 5 minutes and then turn the power back on. Give the oven about 2 to 3 minutes to possibly reset.
If the error code returns, there a few different problems you may have.
  1. The door latch mechanism could be broken or shorted
  2. The may be a pinched or shorted wire
  3. The Oven Control Unit may be bad
If further assistance is needed, please submit the brand and model # of your oven
Apr 15, 2011 • Ovens
1helpful
Have Whirlpool self clean electric oven model # F368LXKQ. Am trying to self clean-get a F5E1 or FSE1 error code and it will not start to self clean/heat. Any idea what the problem is?
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Self Clean will not work. F5E1 Latch not operating
Before you go working too hard to get you oven to go into the self clean (self destruct) mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
1helpful
Oven door is locked and won't open
Sorry to hear the "self clean" Gremlins are at it again. Several things have happened, none good. During the cycle at full power for several hours, a circuit on the control board has failed. Various errors are now keeping functions from occurring normally, although sometimes door switches fail causing similar anomalies. At any rate 'self clean' eventually becomes 'self-destruct'. Boards run 150-300$ . Hope info helps- Thanks-ED
2helpful
Self clean cycle won't start...get message F5E1
F5E1 error means there is a problem with the door latch or relay.
7helpful
3answers
Whilrpool Self Cleaning Range Door won't unlock
try this 1. Verify error code by pressing and holding CANCEL/OFF key for 5 seconds.
Momentarily (less than 5 sec.) press CANCEL key again to remove error code
display.
2. Press and hold any key for 1 minute until F2 E0 code is displayed.
3. Cancel F2 E0 error code.
4. Program and start the clean mode. Observe to see if door locks. If it does not,
inspect the locking mechanism from the solenoid to the latch pawl and door to
find the cause of the problem. If the door is not locking, then 1 minute from the
start of clean, the F5 E1 code will again be displayed. Steps 1 through 3 will
have to be repeated before another clean can be started.
5. Once any mechanical problems with the latch mechanism have been corrected,
program and start a clean cycle (after, if necessary, clearing F5 E1 error code)
to ensure proper operation of the door lock. Immediately cancel the clean mode to observe proper operation of door unlock
Top Whirlpool Kitchen Ranges Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
