Toro Lawn Mower With Toro Power Tools Logo
Posted on Jan 12, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a toro lawnmower model 26624. I think the drive belt is weak and needs to be replaced because it will not move forward when I engage the drive handle. Even though the blades go around. What must I remove to replace the drive belt. Do I have to remove the blade and shrould underneath the mower.
Clyde Ottaway
Level 3:
Loyalty:
Visited the website for 30 consecutive days.
  • Toro Master 1,669 Answers
  • Posted on Jan 30, 2018
Clyde Ottaway
Toro Master
Level 3:
Loyalty:
Answers
1669
Questions
41
Helped
490818
Points
2465
I dont know your model but most drive belts are located under the seat you may have a tenson spring problem
2 Related Answers
Anonymous
  • 33 Answers
  • Posted on Jan 07, 2009
SOURCE: Dual blade mower leaves uncut strips between blades.
it sounds like you need to take the blades off and put a new edge on them which is easy with a bench grinder
kel1guy2002
Kelly
  • 3740 Answers
  • Posted on Apr 15, 2010
SOURCE: Toro lawnmower appears flooded and won't start.
Actually all you have to do is take out the spark plug and pull the engine through several times. What has happened is the intake valve was open when you tipped the motor so when the fuel ran out of the carb into the engine it saturated the spark plug. You may have to by another spark plug to get it started or dry yours out very well. The main thing is to make sure that most of the liquid gas has exited the cylinder.
One more thing.... the float needle may have tilted a bit in the seat as a result of haging it tipped on its side. This is going to sound a bit strange BUT... grasp the handle and alternately bang the front and rear wheels on the ground a couple of times by lifting the back of the mower with the handle about 2 inches and drop it. Do the same by pressing down on the handle for the front tires. (2 inches and drop)
IT WORKS!
This should get you going. IF not just respond here and we can continue troubleshooting.
Kelly
Testimonial: "Thanks for the advice! I followed the suggestion and it worked like a charm. My hats off to you! "
2answers
Lawnmower will not move while running
no ibfo generic answer --check drive belt --popped off --broke--pulley problem--trans axle problem ---key way on wheel sxle damaged or missing
Sep 25, 2023 • Garden
My Husqvarna RZ4623 lawnmower left wheel stopped moving forward and back. Right side moves fine... help.
Check the leftside manual transport bypass lever has not somehow engaged. Compare it to the right side.
The two transaxles are driven by the same belt so extremely unlikely it's a belt problem.
Look for any signs of fluid leaking from the left transaxle shaft seal. If the seal has been leaking then it may be low on fluid. The transaxles are considered maintenance free so there are no instructions from Husqvarna for adding fluid but it can be done. However, if the shaft seal is leaking it will need replaced.
See operators manual regarding bypass levers (rods).
https://www.manualslib.com/manual/74128/Husqvarna-115-127127-Ir.html
Why won't the wheels move forward or backward on my Toro 54" Zero Turn Lawnmower. Was mowing and it stopped moving.
usually if the pins are pulled out that is the freewheel position. push them in to drive. if the trans locks in drive and it is hard to push it should be ready to mow. unless the drive belt is stretched or broken or a linkage is out of adjustment or broken.
Jun 01, 2018 • Toro Garden
Craftsman 6.0 lawnmower frontwheel drive won't engage .
Make sure the belt has not slipped off of the pulley on the engine output shaft just above the cutting blade. It is common with those type of drives for debris to make the belt hop off.
Jun 02, 2010 • Garden
1helpful
2answers
Model #20064 wheels do not turn when you squeeze the bar to engage them. The pulley under the plastic guard spins but not the wheels.
Have you observed what happens under that plastic guard when you squeeze the bar? Do you feel any resistance at all when you sqeeze the bar? The reason I am asking is because there are a number of reasons why this is happening. The drive gearcase is actuated by a spring loaded arm that engages the drive gear to the spinning gear attached to the pulley. A good way to test this is to disconnect the spark plug, raise the mower just enough to lift the wheels off the ground, engage the arm and spin the pulley by hand; if the wheels move then it most likely is the drive cable...if the wheels do not move, it is the gearcase. On a rare occasion it could be the belt is old and stretched out, you can test that easily as well...start the lawnmower, raise the wheels by pushing down on the handlebar and engage the drive by squeezing the handle, if the belt is stretched out, the pulley will move intermittently or not at all.
Hope this helps!
2answers
I have Toro Wheel Horse riding lawnmower model # 70040 - 790000
need the ser number of the unit. the pulley don't split its one part, i need the ser number . this is no easy job. good luck
1helpful
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
