Check on the drain valve /drain pump and test if the voltage comes to the component. If so the drain pump is not working well. You can remove and test on bench, clean and back flush to remove dirt and see for a good flow. Once confirmed refit or else the pump must be replaced if the pump is not performing as required , the coil can be faulty.
However if voltage is not present on the pump after the wash cycle and during the rinse cycle, the controller can be defective.
