Samsung LN52A550 LCD TV Logo
Posted on Aug 27, 2010
SAMSUNG SERIES 5 550 THE TV WILL TRY TO COME ON AND THEN SHUT DOWN AND START OVER.
Anonymous
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on Aug 27, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
16
Questions
0
Helped
5864
Points
43
Most likely failed capacitors in the power supply. I recently had the same problem with my 26 month old Samsung LN46A750. Samsung paid for the installation of an upgraded power supply board.
http://www.thebuzzmedia.com/samsung-tv-capacitor-clicking-issue-and-free-repair/
http://www.avsforum.com/avs-vb/showthread.php?t=1198409
  • Kathhughes Sep 15, 2010
    How did you manage that? Ours clicks on and off, makes a horrendous screeching sound at some point, picture is reverse negative, colors going veritical and then finally switches on and off and goes to a normal picture. Help
tip
Input Switching issues Harmony Remote and Samsung TVs
The following 2008 Samsung TV’s have Anynet+:
LCD
All 9 Series LCD TVs (LNxxA950)
All 8 Series LCD TVs (LNxxA850, LNxxA860)
All 7 Series LCD TVs (LNxxA750)
Most of the 6 Series LCD TVs (LNxxA650, LNxxA630) excluding the 19” and 22” models
All of the 5 Series LCD TVs (LNxxA550, LNxxA540, LNxxA530)
Most of the 4 Series LCD TVs (LNxxA450) excluding the 19”, 22”, and 26” models
Plasma
All 7 Series Plasma TVs (PNxxA750, PNxxA760)
All 6 Series Plasma TVs (PNxxA650)
All 5 Series Plasma TVs (PNxxA550, PNxxA530)
Half of the 4 Series Plasma TVs (PNxxA450) excluding the 410 line (PNxxA410)
DLP
All 7 Series DLP TV’s (HLxxA750)
All 6 Series DLP TV’s (HLxxA650)
All 5 Series DLP TV’s (HLxxA510)
2007 Samsung TVs With Anynet+
The following 2007 Samsung TVs have Anynet+:
Note: Excluding all 26" models and below.
LCD
All 81F series (LN-Txx81F)
All 71F series (LN-Txx71F)
All 65F series (LN-Txx65F)
All 61F series (LN-Txx61F)
All 53H series (LN-Txx53H)
Plasma
FP-T5084
FP-T6374
HP-T4254
HP-T4264
HP-T5054
HP-T5064
DLP
All 89S series
HL-Txx89S
HL-T7288W
Information on Samsung TVs that support AnyNet has been refered to from: http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view.jsp?isARS=Y&SITE_ID=1&AT_ID=18104&ARS_ID=8514159
How To Disable Samsung Anynet+ so your Harmony Remote Control properly controls your devices. This mainly impacts Input Switching.
1) Press your Tools Button.
2) Scroll down to Anynet and press your Select Button.
3) Once on the Anynet screen, please press your Left/Right Button(s) to select the Off Setting on the Anynet+ (HDMI-CEC)
4) Scroll down to the Auto Turn Off and select No.
Once this is completed, please turn off your TV and all device and power them back on using the Harmony Remote. Also please test this in the Activities mode, if this does not work, let me know
tip
Input Switching Issues with Harmony and Samsung TV's
LCD
Plasma
DLP
LCD
Plasma
FP-T5084
FP-T6374
HP-T4254
HP-T4264
HP-T5054
HP-T5064
DLP
All 89S series
HL-Txx89S
HL-T7288W
Once this is completed, please turn off your TV and all device and power them back on using the Harmony Remote. Also please test this in the Activities mode, if this does not work, please e-mail us back for further assistance.
Samsung tv series sq01 has check fan 2 on screen then will shut off where is fan 2 located and what does this mean
you will need the complete model/serial number for proper part#. To locate which fan is problem try watching to see which one is not coming on at start-up.
Tv will turn on, for about 30 seconds, then it will shut down
Hello
There are two main reaons for this fault. The first is with its power regulator board itself. If it has any loose soldering points developed, this type of intermittent fault can occur. The second is with its light engine. If you want to do this work by yourself, you must have thorough knoledge in electroncis, and must have all tools and ability to follow its schematic diagram. The most you need is patience. If you have these all, and want to do the repairwork by yoursef, inform me. I've the schematics of your tV, and all repair adjustments and proceedings. The power supply board and lamp ballast boards for Samsung (HL-T) series are shown here for your referecne. The lamp ballast board also may need to be checked.
2answers
TV wont stay on.
Similar problem with my Sony. unplug for 36 hours and try again
TXM3297HF Samsung TV shuts Down
Hi!! Kindly check the power supply section if their is a defective resistor or semiconductor device..thank you.
2answers
My smart series magnavox keeps shutting off................
switch-mode power suppy is flaking out.
when it does that its hard on your high voltage circuits so get it fixed or it might turn to a huge bill.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
