SOURCE: Driver does not retract after striking a nail
if its new warranty it,
otherwise all it should need is a rebuild kit . its just a bunch of orings and gaskets. pretty easy to do. take some pictures as you take it apart to help with reassembly.
Dewalt should have scematics online or ereplacements.com
SOURCE: Remington Powder Actuated Tool Model 476D. Ram set.
the tool got stuck, after a shot, it stayed up and I cannot release it to put a bullet and a nail for the next shot, what can I do, I tried to undo the nut in the top of the tool with no success.
SOURCE: I have a shell stuck
Simple take a wood screw and insert it in the spent shell. Gently apply downward pressure while turning the screw a partial thread in. Then use a pair of needle nose pliers to pull it out using the 476's casing as a leverage point. Just did this and worked well. Allen key and pocket knife ideas did not work as the shell is too tight in the chamber.
