Broken Usb flash drive male end of drive fell off looks like a soldering job .
But is it possible to recover the data on it? Break very clean i cant see any
metal fatigue four metal leads intact .Is it possible to reconnect?
Thnks in advance.
T.R.
Does the flash drive been detected by computer? If not, you may try other usb port, or other computer and see whether the flash drive is detected. If still not, try to go to device manager and then assign a drive letter to the flash drive. After that, download a flash drive data recovery software, recommended asoftech data recovery, you can refer to this tutorial
How to recover files from usb drive
If still does not work, you may format it (use quick format) and then use asoftech data recovery to recover your files.
Here's a video tutorial I find very useful
I have just repaired my own flashdrive. I took the outer casing off. On the underside there are 2 small clasps soldered onto the side of the drive. I pinched them back onto the drive wit pliers and hoped for the best. Suprisingly and joyfully it worked. I hope this helps someone.
Quick update from the original guys from 24hrR, we are now "www.FlashDrivePros.com" formerly "www.FlashBackRecovery.com", it will be in effect soon enough.
Right now student pricing is now available. If you chat with us online, you may get a discount.
Thanks www.JennyReviews.com for the great review on us:
http://www.jennyreviews.com/how-to/how-to-recoverrepair-data-from-broken-flash-drive/
Check it out...
These guys recoverd my files from my broken-in-two-pieces flash drive in less than a day for $45. I just download the files off the internet when they were done.
I think you can find them if you search "broken flash drive" in Ebay. They are called 24 hour data recovery.
Or maybe this link will work..
http://cgi.ebay.com/Files-Data-Recovery-for-Broken-USB-Flash-Thumb-Drive_W0QQitemZ160319911030QQcmdZViewItemQQptZPCC_Drives_Storage_Internal?hash=item160319911030&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
Juban
check out this useful site as well:
http://www.flash-drive-repair.com
other than that....
check out these guys....http://flashdrivepros.com
We do next-day flash drive data recovery for under $100 ($50 for currently enrolled students)
Just send us your drive and download your files the next day or get a full refund.
www.24hourdatarecovery.com
Www.SaveMyUSB.com
See this guide:
Recover files from USB flash drive
Just the Data Recovery to get the lost files in 4 steps.
If the broken USB can still be identified by a PC, then you will still have a chance to recover the lost files from it.
Please plug the USB into a PC, and then you can recover files deleted from USB step by step by using the tool.
When you delete pictures (or any files) from a memory card or USB memory device the data itself isn't deleted, just the file system pointers that says where the data for those files is located. The area where the deleted picture data was stored is also now marked as free space so it is available to the system for any new files to be written there instead.
If and when that happens, then it is not too late to recover your deleted pictures , you can get Tenorshare Data Recovery to recover.
Download from http://www.any-data-recovery.com/product/datarecoveryprofessional.htm
I have ever restore Samsung galaxy nexus with this tool, and I know this tool also can help you too.
My flash drive is loose or something so it doesnt read in the computerDX and idk what to do, who to choose to fix it, whos cheap but will do a good job..that USB has photos an documents i need..im an entering college student who doesnt have the money to spend ALOT of money on it but i really want to get it fixed...any good suggestions??? thank you!
Thanks, that links has the information and helps me to recover al lmy data from a 8 gb flash drive broken
Trying to do it yourself could often cause more damage than is already done. Consulting a professional is a smart move or at least try and get as much information as possible if you are going to try and do it yourself. While it might be cheap to replace a broken flash drive, the data on there is probably not replaceable for most people.
I got great help form this site
http://www.recovermyflashdrive.com/
Yeh im pretty sure u can try this website
http://www.hardwaresecrets.com/article/267/2
This site helped me when my flash drive was broken
My silicon sd memory card 2gb was broken can any one give me solution
my flash disk can't be opened, every time i pluged in the "please insert disk" sign appeared. How can i restore my data? Thax (novel)
How can i fix a flash drive where I can see the male ends (4) and the female ends but cannot get the light to turn on?
Yes my girlfriends drive as the male end drop off! any other solutions I am trying a computer shop but might DIY myself
Craig
UK
My brother stepped on my flashdrive and snapped it in two pieces right down the middle.
I accidentally broke my flash drive as it was in my PC. It's bent and I have all my pictures on this one flash drive. Can they be recovered? It's a 2 gig Attache.
i have the same problem as novelpri
