SOURCE: Printer causes Flash Drive and Ipod to not work
Even better connect the Printer to the USB hub and the Ipod to the PC. Its a better idea to isolate the printer. Also if you have another USB cable you can use for the printer that might help as well. There are some bumb usb cables out there.
SOURCE: Kodak G610 prints from docked camera, but not from the computer
it is advisable to use a recomended usb cable for your printer dock. you can try also to uninstall and reinstall the printer driver on your computer. just simply follow this steps:
Remove the drivers that your operating system automatically installed on your computer:
-- On your desktop, select Start > Settings > Control Panel > Printers & Faxes.
-- Remove all Kodak printers.
Right-click the printer icon.
Select Delete.
-- On your desktop, right-click My Computer, then select Properties.
-- Select the Hardware tab.
-- Click Device Manager.
-- In the Universal Serial Bus controllers list, right-click USB Composite Device, then select Uninstall.
note: make sure that the only device connected to your computer usb port is your G610 printer dock to make sure that the USB Composite Device that you uninstall is for your G610, most of the devices connected to you usb port has USB Composite Device also.
-- In the Imaging devices list, if any Kodak printers appear, right-click the Kodak device, then select Uninstall.
-- Disconnect the USB cable from your printer.
-- Restart the computer
-- Power Cycle the printer
-- once your computer is ready connect the G610 to your computer
-- check if you have a pop up window display on your computer informing you that your computer found a hardware device
-- you can go to printer and faxes and check if the G610 printer icon is on the list
-- try to make a test print
Verify that your computer is communicating with your printer:
-- Check that your printer is on.
-- verify if the USB cable meets your printer specifications.
-- Check that the USB cable and the power cord are securely connected to your printer and your computer.
SOURCE: just reloaded both printer inks. Does not show
where did you see the ink status? On you rcomputer while pritning to an apllication? If yes dont worry about that its not that accurate., You may see the correct details about ink status if you launch your home center software and you will see there your ink status just click the help icon(?)., and also you can see ink status in your 5300 printer right? Press menu and scroll down and look for the ink status.,
I also encountered that same problem so dont owrry about that., or may be you can download also the latest firmware of your printer at
kodak.com/go/downloads
SOURCE: Easyshare 5300 communication error?
Hi there , When you click Print , it offers you Printing options before you print, Make sure you select the Correct Printer To be used , before you click Print , This has been a issue with Office and Windows Vista that i personal experienced...Hope this will help.
Also try the printer on a different PC or laptop/notebook , and if it works on them , then it is a PC related problem , if it doesnt then the Printer Could be faulty now.
Thanks
SOURCE: I have a kodak 5300 printer. I recently had the
Reinstall your windows or 'Recover' or 'Restore' to an earlier date, perhaps to the original 'new' date.
Let the operating system find the drivers for your printer again, or install the right drivers for your operating system and printer combination, off of the website for Kodak.
Good luck.
For QuickBooks Pro, Premier, and Enterprise Solutions working on the Windows XP platform:
For QuickBooks Pro, Premier, and Enterprise Solutions working on the Windows Vista platform:
For QuickBooks Pro, Premier, and Enterprise Solutions working on the Windows 7 platform:
