Lexicon RV-8 wakupe failure
Did you try this....
In the event of a power outage, the RV-8 will display a BROWN
OUT!! PRESS STANDBY message. To turn the unit on, use the
STANDBY button. For more information, see “POWER
MANAGEMENT” on page 3-3....
POWER MANAGEMENT ON, OFF
"Setup" >> "Power Management"
Opens the POWER MANAGEMENT menu, which is used to automatically
put the RV-8 into standby mode during brownouts.
When set to ON, the RV-8 detects low voltage levels or a momentary
loss of power and puts the device in standby mode. In the event of a
power brown out, the RV-8 will display a BROWN OUT!! PRESS
STANDBY message. To turn the unit back on, use the front panel
STANDYBY button.
When set to OFF, the RV-8 will attempt to function during a
momentary power loss, however software settings may become
corrupt and need to be reset.
When the RV-8 is in standby mode, pressing the button turns the
unit on and activates all zones that were active in the previous
operating session.
The RV-8 does not power on.
1. Make sure the rear-panel power switch is set to the | (“on”)
position.
2. Attempt to power on the RV-8 with the front-panel Standby
button and remote control On button.
3. Examine the power cord to ensure a good connection between
the rear-panel AC input connector and the wall outlet.
4. Check the electrical circuit and breaker.
