Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13 In Logo
Posted on Aug 13, 2010
Te76 will run but will not hammer - Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13 In
  • Wahid Amir Oct 09, 2019
    My Hilti Jackhammer te 76 p is not hammering
    I want to change the oil which use for hilti te76p
Anonymous
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Feb 02, 2011
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
0
Helped
7632
Points
19
THE TOOL IS LOW ON OIL. OR POSSILBE SEAL ISSUE, IT TAKES ITS OWN OIL, HAVE TO GET IT FROM HILTI!!! BE PREPARED YOU HAVE TO BUY A GALLON AT A TIME! IT HURTS!!! OR YOU CAN SEND IT TO HILTI AND YES THEY WILL BE MORE THAN HAPPY TO FIX IT FOR YOU OR GIVE YOU CREDIT TOWARD A NEW ONE, THATS HOW THEY WORK!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 05, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
2486
Points
Hi I have Hilti TE76 ATC but i like to change oil. What kind of oil I can use. Tell me the best oil. My device still work.
    Same problem
1 Related Answer
Anonymous
  • 2176 Answers
  • Posted on Jan 27, 2009
SOURCE: Problem with Hilti JackHammer TE76
Yes there is but it is somewhat confusing to navigate. It is Hilti.com. If you can give me some idea what parts you are looking for I have that breakdown at work and will help you. It is the TE76. Let me know and I will do what I can or you can call their toll free number in the US at 1-800-879-8000 and ask them for help also
1helpful
2helpful
2answers
How to reset te76 atc module
Eto rabotaet. Spasibo!
Its working. Thanks!
The service light has come on on my te72
The TE72 did not have a sevice light. The TE76 did. If that is your model then the brushes need to be changed
Mar 18, 2012 • Drills
5helpful
HELLO I HAVE THE HILTI TE76-ATC WITH CODE 330200 WE CHANGED CARBONS . HOW I CAN MAKE THE RED LIGHT FROM ON TO OFF.
Are you mechanically inclined??? This is a little involved to do. First UNPLUG tool and remove the back section/trigger, there are about 6 screws holding the assembly to the back of the tool. REMOVE as an assembly. SQUEEZE trigger and PLUG into electrical outlet, while holding trigger unplug and reassemble, try this if light still on plug assembly in squeeze trigger and while holding the trigger unplug and retry. One if these should take care of resetting the light. If not the only other way is to send it to HILTI and have them reset it. Let me know if you still need more assistance and results.
Feb 17, 2012 • Drills
Need a rotor for hilti te76-atc part #330427
In the states contact Hilti @ 1-800-879-8000
2helpful
How to reset Active Torque Control in the handle of Hilti model TE76P-ATC Rotary Hammer Drill
Active Torque Control (only TE 76-ATC / TE 76P-ATC)
The TE76-ATC / TE 76P-ATC is equipped with the Active
Torque Control system in addition to the mechanical
torque limiting clutch. This system offers additional protection
while drilling by rapid shutdown upon uncontrolled
rotation in the axis of the drill bit, e. g. when the
drill bit jams due to hitting rebar or when the insert tool
is tilted unintentionally.
When the ATC system has become activated, the tool
can be restarted by releasing the control switch and reengaging
it after the the motor has stopped rotating
("click"-sound signals readiness for use).
Always choose a working position in which the electric
tool is free to rotate in a counter-clockwise direction
(as seen by the operator). If this is not possible, the ATC
system cannot react.
25helpful
3answers
Hi, My hammer drill HILTI TE76-ATC has service red light on. How can I solve this problem? Thanks
Hi. It all depends on the age of it as there are 2 different types of electronics fitted to the TE76.
If you have an early model, the service light came on when the brushes were worn or it was in need of a service. Check your brushes 1st. then to reset the light, simply pull the trigger and hold it untill it resets.
If you have the newer type then you will need to reset the service light by attaching a data reader to the service light. this data reader plugs in to a PC, you will also need the HILTI ODA Software to go with it. Basicaly you need to send it back to hilti to have is serviced and reset. if your machine is less than 2 years old, this is FREE. just phone hilti and ask them to collect it. they will pick it up, service it and get it back to you in 3 working days. if you not sure how old your machine is simply phone Hilti and ask them, quoting the serial number. this is etched into the plastic on the left side of the machine underneath the white writing on the motor housing. Good Luck
Sep 25, 2009 • Drills
3helpful
2answers
Red service light on ,have checked brushes and they are as new, won't operate at all
3helpful
2answers
Top Hilti Drills Experts
Paul Bade
Ngoro
john h
Are you a Hilti Drill Expert? Answer questions, earn points and help others
