Danby DWC283BLS Wine Cooler Logo
Posted on Aug 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Set temp to 42 and 54 but unit stays at 75. HELP!
Anonymous
Level 3:
  • Master 1,891 Answers
  • Posted on Aug 10, 2010
Anonymous
Master
Level 3:
Answers
1891
Questions
0
Helped
409423
Points
5205
Sounds like the compressor is not running . ck the connectons at compressor and listen for a click in the cold control as it may be bad .. / noises like clicking at compresor . may be the relay that starts it .. mm
Digital temperature changes to 86 every time your set it to a lower temperature how do I fix this
If this set temp changes on its own then the circuit board has failed. Call a service tech or replace the unit. But this 86° might be the indoor temp, not the set temp? If I set my temp to 75°, then my temp goes to 86°, then the set temp (target temp) is 75° & actual room temp is 86°. The unit may not be working properly. Not sure if this helps.
Outside unit runs for about 5 seconds then shuts off for a few seconds. It repeats this cycle.
Put in a 5 minute time delay. It is a two wire device in line with the contactor. Sounds like it is set to 75 turns of at 74 and repeats. The tstat should have a differential of 2 degrees as well.
Remote is inaccurate
did you change the batteries ?
Upper & lower level does not cool. Temperature stays at 78 for lower level & 75 for upper. In attempting to set cooler temperature at 55 for top and 45 for lower it immediately reverts back to 78...
take shelves off. temp display unit in middle of shelf is where circuit board is for testing. pull middle unit forward and unscrew back panel. check lines for leak. color should look like a teal green. thats where your leak will be. Need tech. for the rest.......good luck!!!!
We have a MXZ-3A30NA that does not seem to be cooling down the house. Indoor temps are reading 75 to 78 degrees and the units are set at 65. We have gone through the book and have followed the check list...
Hi!!
Check the following:
Make sure the filter and the evaporator coil are clean. Also check condenser coil in the outside unit is clean.
When unit is turned on there should be (on the led display, inside unit) one green light on for the blower and another one for the compressor, both lights should be ON untill the unit reaches the preset temp. If the light for the compressor (usually the light on the right side) does not stay ON, check the outside unit.
On the outside unit, check that when turned on, both the fan and the compressor kick in and stay running. If the fan motor stops, the compressor overheats and the thermal proteccion shuts it down to prevent damage. Also, if the R22 gas is low, the low pressure switch prevents the compressor from running.
Good Luck!!
2helpful
2answers
My air conditioner will kick on but will stay on and not
The thermostat is not functional, therefore its not cutting off the compressor once the room air gets cooled to the temp setting of the thermostat, also the refrigerant gas may have leaked out some but not the entire refrigerant gas(freon, CF4, etc.), keeping the compressor running contentiously to come down to the set temp..............sodeep
Our thermostat is set at hold with the fan on auto. The house and cool temp is set at 75 degrees, yet the fan will stay on CONTINUOUSLY unless I manually take down the temperature OR the outside temp falls...
it is ok to run your fan continously. constant air filtering as long as it pauses before a/c cycles on. will not use any more electricity than a toaster. is there a fan programing feature on t-stat. if so you will need to turn programing to fan off
Oven won't heat up at all.
broiler on top of oven?? if so it might have a second ignitor that is working. Most units now with gas have an electric ignitor to start gas ovens. What they do is send electric current through an electric "wire", when enough current is flowing through wire to open gas valve the wire is hot enough to ignite the gas flowing over it. When you turn on the oven look at the burner and after 1 imute or so you should be able to see an Orange glow in bottom of oven if not I'm sure its the ignitor, if glows then probably oven valve is bad. I'd guess ignitor because most oven makers use this ignitor to mantain a warming temp (around 100 degree's) so since your display doesnt register over inital "start" temp of 75, i'd bet ingitor not coming on at all
Hotpoint oven
does the display go to 425 or are you putting a dial thermometer in it?is the new control doing the same thing as the old control?
Edgestar 12000 heating problem
bad thermostat. the stat can be as must as 5 degrees off. try, if possible testing the unit in a differeent location
Top Danby Furniture Experts
ZJ Limited
ZJ Limited
Are you a Danby Furniture Expert? Answer questions, earn points and help others
