Refrigerators Logo
Posted on Aug 09, 2010
I have a Magic Chef beverage cooler, MCBC580DBT, it no longer cools, its a 2007, the power is on, the light and the thermostat work, the compressor does not turn on to cool. I replaced the ptc starter and the motor protector. Still not working. There were no signs of distress before it quite, it was cooling right up until the day it stopped. Is there anything else I can replace myself, like the temp Control Pc board, that will fix the problem, or anything else you can think of.
  • Ambika Datta
    Ambika Datta May 18, 2020
    Can you jump the red and brown wire plugged in into the circuit board?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 25, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
23366
Points
8
Same problem w mine and yes if you take the cover off the inside display you will be able to remove the board mine has a hole burnt in it.unplug harness w red blue and brown wires and jump and jump from brown to red unit will turn on you need a new board
  • 8 more comments
  • Anonymous Jan 02, 2011
    just an update resoldered back of pc board, damaged area was obvious,re-installed pc board unit works perfect. this is a two minute fix once board is removed from inside of unit inside light and temp control houseing.
  • philcousinea Apr 23, 2011
    I had the same problem, you are correct, the solder was a simple fix. I was also able to find the pc board on line as well for $55.00.
  • Anonymous Feb 18, 2012
    Thanks Dodge1up. 1 blackened pin with no solder on it. After putting solder on it and putting it back together. Compressor came on. Such a simple fix...once you know where to look.
  • Anonymous Feb 24, 2013
    Same problem - removed the circuit board, found one burnt connection. A simple dollop of solder and the compressor kicked back on. TeeEssGee 1, Planned Obsolescence 0.
  • Ross Luxon
    Ross Luxon Aug 28, 2014
    Where was the burnt connection? I seem to have a few spots that look blacker than others?
  • Craig Hamilton Mar 30, 2017
    Awesome, same problem but this fixed it!
  • Brent Corey Oct 28, 2017
    I replaced my board (which I've already done before a while back), but the unit doesn't appear to be cooling? It's running again, but there is an occasional "click" & no temperature drop? Suggestions?
  • Best Konstruksi
    Best Konstruksi Mar 17, 2018
  • Arief Rachman Depari
    Arief Rachman Depari Nov 26, 2018
    https://citrusarsitek.com/
    https://chocowebdesign.com/
  • Billy Bob
    Billy Bob Jan 23, 2019
    Pulled my board after replacing the ptc, I did the jump and everything started up. I am looking at the board and unfortunately no black or missing solder.
Butch Howard
Level 1:
New Friend:
  • Posted on Jul 22, 2016
Butch Howard
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
23366
Points
6
I have a Magic Chef MCWC50DST model purchased about 6 years ago from Home Depot that just died one night. I replaced the starter relay - no joy. I followed the jumper instructions above (control board - wired the brown to red wire) and determined the problem was the control board. After removing the control board the problem was obvious - burned connection. I used my old solder iron to add a new bead to the connection, re-installed the board and it started right up! Thanks for the advice
I have a Magic Chef beverage cooler, MCBC580DBT, - magic-chef-beverage-cooler-mcbc580dbt-d0kyft0vctxwdzim0savdwbd-5-0.jpg
  • joeo
    joeo Jun 11, 2017
    Same problem. Easy Fix. Thanks for the insight and saving me a bunch of $$$. Cool (pun intended).
  • Billy Bob
    Thanks, I took mine out, did not find anything on the board but one joint looked less than stellar so soldered that , and when I took the board out found a piece of the metal casing resting on the board crossing a circuit. Works now, so will never know if removing metal that fell out of the hole where the wires come through of if the solder did the job but its running.
Anonymous
Level 1:
New Friend:
  • Posted on Apr 14, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
23366
Points
You guys are amazing. Had the same issue. Took longer to gather up the supplies. Two minutes to heat up the soldering iron and the board was fixed. Amazing. Thanks
  • Anonymous Apr 14, 2012
  • lowrateguy Sep 19, 2013
    Would it be possible to not replace board and just leave the jump? I would then put fridge on 24 hour timer to go on for 30 min then off 30 min etc.
MichaelZ
Level 1:
New Friend:
  • Posted on Sep 08, 2016
MichaelZ
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
23366
Points
I had the exact same problem that Butch Howard had. Based on his post I took the control board out and flipped it over - same solder joint was missing. I replaced it - put the fridge back together and it turned on. 12 hours later - nice and cold and running fine. If you have a problem with this fridge you should start here!
Thanks!
MZ
Don Viecelli
Level 1:
Habit-Forming:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 2 Answers
  • Posted on Apr 01, 2016
Don Viecelli
Contributor
Level 1:
Habit-Forming:
New Friend:
Welcome Back:
Answers
Questions
Helped
24626
Points
6
I replaced starter relay also, but not the problem. Unit works until temperature setting reached, then shuts down. If I bang on unit or restart, unit works until temperature reached. Control board looks and works okay. What else can I try?
  • Don Viecelli
    Don Viecelli Apr 04, 2016
    Found part of the answer to my problem. Wires on the 3-wire connector near the light bulb were loose. Pushed in one or two wires and unit turned on. Testing now to see if temperature holds.
  • Don Viecelli
    Don Viecelli Apr 05, 2016
    The connector was not the final problem. When I press on the relay, PN JQX-102F-P, the unit starts or stops. Something is wrong with the part or board. Replacing board, PN WBS-165-1.
2answers
We have a Magic Chef MCWC52B
The light may be old, and need repairing, I would try contacting somebody local rather than buying a new one.
My dual zone wine cooler stopped cooling. Power is good and fan is working.
Fan is wired separately from the cooling unit. you may have a wire corrosion issue. take put the shelves, disassemble the back of the unit from the inside and observe the wiring to see if there are broken or corroded wires/connections. R/R if necessary.
The Magic Chef Refrigerator Electronic Thermostat - SF-WB-4/CM will only cool to 45 degrees, Is it possible to change out the thermostat with another factory unit fom a standard mini frig ?
Putting another thermostat would not help it be cooler it actually stop it from functioning all together if it's not recommended by the manufacturer
2answers
3answers
HH error code? on magic chef mcbc580dbt
I, too, have just seen (late June 2013) the "HH" code on my Magic Chef wine cooler (and it is running too cold and I can't reset the temperature). Have you found a solution since your posting of about 1 year ago?
12helpful
Quite working out of the blue. light works but no cooling it is a Magic chef wine cooler model mcwc30mcg
if its clicking every few min. its the ptc relay.left of compressor is a shield with 1 screw.behind it on top is the relay with 1 wire going to it.wiggle it out to the left .go to repairclinic.com..part#1206838...
The magic chef wine cooler was clicking now will not get cool .
its your ptc relay.its a very simple fix.to the left of the compressor is a plastic cover with 1 screw.take it off.youll see a small box on top with 1 wire going to it.wiggle it off.pulls straight out left of compressor.go to repairclinic.com..type in part #1206838.its about a $27.00 fix. mines been running fine since.hope this helps
Magic Chef refrigerator stop cooling
check the fan relay and the compressor to make sure it is still working...if not there is a capasiter you can replace to get it to work again
Top Magic Chef Refrigerators Experts
Kardoc
vince
Paul Carew
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
