Vacuums Logo
Posted on Aug 09, 2010
I need operating instructions for a 2 year old Nespresso c250
tyala
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 05, 2011
tyala
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1129
Points
For Nespresso C250, you can look up Krups 554 or 580 and I found this manual http://safemanuals.com/user-guide-instructions-owner-manual/KRUPS/NESPRESSO-PROGRAMATIC-554-_E for download. I'm pretty sure this is the one!
I cannot hold power button down for very long on our Dyson v8 animal cordless vacuum. Is there a replacement switch I can fit that would make it click on/off rather than press and hold to operate?
Most rechargeable Dysons only last 2 years before failure. If it's 2 years old, the power control board is failing. It is disposable.
Hi I have a dc35 which was working ok but now the charger light keeps flashing and it wont work could someone give me advice please thanks Ryan
Dyson DC35
Approx 4 years old?
1. Check and clean the filter.
2. Release the battery and clean the battery terminals both on the battery and the vacuum. A small thin screwdriver is ideal.
3. put back together and check operation.
hope this helps
Dec 01, 2014 • Vacuums
1helpful
2answers
How often and how do I descale my nespresso citiz? I cannot find my manual!
I worked for Nespresso for 2 years and YOU DO NOT descale every 30 days. You will clean your machine ONCE A YEAR or every 600 capsules. You will know your capsule count via your nespresso account. A representative can relay that information
Feb 14, 2011 • Vacuums
I have a 30 year old TriStar (bullet style with thick bumper gasket around the middle) and the High/Low speed switch is burnt out. I am trying to find instructions for how to separate the shell to get to...
you remove the screw up front and the 2 scews buy the the rewheels from the bottom and then you pry the shell apart from the gasket it is tight but once you get it to loosen it come easy
Feb 25, 2010 • Vacuums
2answers
Vacuum is about 4 years old does not pick up well
Have you ever replaced the belt? That is most likely the reason that it is not picking up like it used to. You are actually supposed to change the belt yearly. Here is the belt you need and the manual which has instructions:
Dyson DC07 Belts and Manual
I have a Kerrick lava flow wet/dry vacuum cleaner
Dear Sir, I also have a Kerrick Lava Press cleaner that came not with very good instructions and I have never used it. Where could I get instructions?
Christa Unnasch
2 Torrens Lane
Mawson Lakes
S.A. 5095
Australia
[email protected]
Aug 19, 2009 • Vacuums
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
