SOURCE: D-Link Print Server Compatibility issues
DP-300U Print Server is not compatible with Sharp AR-5320. Pls check D-Link website on the list of compatible printer. For USB Print Server that is compatible with Sharp AR-5320 try Intellinet.
SOURCE: Hard reset to clear paper jam error
Most likely you need to carefully go through the paper path and look for the locations of all the paper path sensors.
You probably have one stuck on the frame or a spring came off the flag and its not actuating properly.
Follow the paper path carefully from the feed rolls out to the exit. I am sure you will find a sensor not operating properly.
Actuate every one and make sure they have no resistance and that they return to the proper position.
SOURCE: Windows Vista Printer Driver
Go to: http://www.sharpusa.com/products/business/copiers/business_copiers_drivers/
and select the copier and OS that you use. Download the PCL5e driver. When you finish downloading, you might have to extract it from the zip format, then run the setup.exe file and follow the prompts.
Don't forget to rate your answers please!
SOURCE: sharp am 400 driver dowmload for vista
There arent any drivers for AM-400 and vista!
AM-400 are only working whit XP, Milleniun and Win2000
Nic
