Problem:
Cause:
Solution:
Fixed!
Did not fix.
TRY FIRST (Solutions without parts):1. Door A not closed properly. - Open and close door A, then power cycle the
printer and check for the error again.
2. The rails that the
print cartridges slide in are misaligned or bent. - Remove the Transfer belt and all
print drums, then check and re-align
print drum rail guide. Then reassemble and verify proper operation.
3. Interlock actuator tab for the front door is broken off. - Check the interlock actuators on the front door if misaligned or broken then replace the front door, if they can be reconstructed then repair. Otherwise call for additional parts.
4. Cable connection to the Engine control board is not seated properly or fully. - Check all cable harness and wires to the Engine control board and make sure proper connection is made.
TROUBLESHOOTING TIPS AND HINTS:Check all media trays, access doors, and front cover for proper closure and interlocks being disabled.
