Apache 450 rlx sport turns over but compression seems too high and seems to lock up
The engine remove the spark plus turns over rapid and good refit the plug and turns over then seems to slow down and go right on the engine any help ????? Thanks
I have the same quad with the same problem,its done every experts head in,take the seat off and look down the left hand side of the inlet manifold there should be a small peice of rubber hose about an inch or so,check to see if it has a screw in it or a plug if not put a screw in it,it will then rev higher just turn the rev screw on the right of the carb outwards untill tick over is about 1700rpm
