My HFA290GB Hoover Frost Free Fridge Freezer has to be deiced every 2/3 wks. so we can open the bottom drawer the ice is app. 10m/m thick,plus the fridge part is not very cold, 5yrs.old,the old one that this replaced was 20yrs old.HELP.
That is normally indicative of a failed gasket and not sealing properly. The warm moist air is sucked in and condenses to frost. You should be able to trap and grip a 2" strip of normal printing paper all the way around it.
Look at the door on the ice cube chute. If there is a cube stuck in it holding it open, ice will form on interior surfaces of the freezer. The door flapper must close tightly.
for no frost type;cleaning of freezer cub underneat is a must...cloggged drain outlet buildup thick frost on your freezer cub..
.ie..for frost type;you must set your thermostat setting to normal,replace it with new one
You may have an issue with the temperature control assembly. Check the temperature settings (ideally at "one-half way" for both fresh food and freezer compartments).
During the defrost cycle heaters in the wall of the freezer are turned on to melt the frost build up. This melted frost "water" is supposed to run out a drain in the bottom of the freezer and collect in a pan under the refrigerator/freezer where it will eventually evaporate. If this drain is blocked it will cause a lot of water to collect in the bottom of the freezer and that water will eventually turn back into ice. I recommend defrosting the freezer manually, removing all the ice/water buildup in the bottom, and trying to unplug the drain line to the pan underneath. Also check the seal on the freezer door. If it's not sealing well it could be letting a lot of moisture enter the freezer which would lead to more frost buildup and more water during the defrost cycle.
The adjusta cube ice maker has an on/off switch. To stop the ice from overfilling and being knocked off when you open the freezer door turn the ice maker off and then back on as needed.
